Author Topic: 1969 Muncie Transmission  (Read 6434 times)
wisemanz28
« on: March 03, 2015, 10:06:38 PM »
When did they start using bolts ( instead of using nuts ) to attach shifter rod levers on a 1969 Muncie transmission ? The transmission is a 660 main case and has a 306 side cover.
rszmjt
Re: 1969 Muncie Transmission
« Reply #1 on: March 04, 2015, 01:17:39 AM »
All 1969 Muncie trans used bolts, the flattened 3/8 type stud was 1968 and earlier
HOGDADDY
« Reply #2 on: March 27, 2015, 09:58:22 PM »
I have a 69 trans with earlier shifter rod mounting studs installed.
« Reply #3 on: March 27, 2015, 10:15:46 PM »
Might have been modified over the years.  What is the casting number on the side cover?
VINCE Z28
« Reply #4 on: March 28, 2015, 02:22:54 AM »
Early 69 Muncie, Aug.19th 1968.
VINCE Z28
« Reply #5 on: March 28, 2015, 02:29:18 AM »
One more.
HOGDADDY
« Reply #6 on: March 30, 2015, 09:46:56 PM »
3950306 is the number. I think it was modified to fit earlier Camaro.
