Author Topic: Steering Column Assembly Broadcast Codes  (Read 25657 times)
Camarocards
« on: March 01, 2015, 05:21:53 PM »
Does anyone know the broadcast codes for the steering column assemblies listed below?
5698494 - '67 standard column shift
7803775 - '67-68 PG column shift except tilt wheel
7803780 - '67-68 TH column shift except tilt wheel
7803778 - '67-68 PG or TH column shift with tilt wheel
7803779 - '67-68 floor shift with tilt wheel
7803776 - '68 standard column shift
7804299 - '69 standard column shift
7804298 - '69 AT column shift except tilt wheel
7808153 - '69 AT column shift with tilt wheel
7808154 - '69 floor shift with tilt wheel
Bob
Bob
'68 SS L35 01D
Camarocards
Re: Steering Column Assembly Broadcast Codes
« Reply #1 on: March 05, 2015, 07:19:53 PM »
I've identified a broadcast code for one of the steering column assemblies listed in my original post:
TN 7803779 - '67-68 floor shift with tilt whee
Does anyone have their broadcast sheet and could help with some of the others?
Bobl
Bob
'68 SS L35 01D
« Reply #2 on: March 10, 2015, 02:38:27 AM »
Sorry, but that's not correct.
TN is 67 floor shift *without* tilt. I don't think TN was used in 68.
« Reply #3 on: March 10, 2015, 04:37:23 AM »
That seems correct, Kurt. I checked my 67 4SP Muncie and the reddish color tag at the bottom of the standard steering column has 'TN' on it.
I'll check the 67 TH400 for a tag.
Mark
« Reply #4 on: March 10, 2015, 11:06:10 AM »
Heres the tag on the top of my steering column, 1969 floor shift automatic with tilt.  Looks like KB  7808154
Mark C.
1969 Indy Pace Car
350/300HP RPO Z11
big iron
« Reply #5 on: March 10, 2015, 05:32:06 PM »
Kurts,
Same assembly number for both years (69 P&A), need to check earlier P&A. Only thing different is the 4 way flasher. Would that difference change the broadcast code?
Bob
« Reply #6 on: March 11, 2015, 01:50:12 AM »
I don't know, but in 68, floor shift non-tilt was CN, not TN.
« Reply #7 on: March 11, 2015, 02:03:21 AM »
Remember, service part assemblies are different than production part assemblies.  :)
Camarocards
« Reply #8 on: March 11, 2015, 02:23:31 AM »
Yes. Agreed. My '68 floor shift non-tilt carries the CN code.
Bob
Bob
'68 SS L35 01D
big iron
« Reply #9 on: March 11, 2015, 02:56:16 AM »
Are you saying that they are different physically or have different part numbers?
Bob
big iron
« Reply #10 on: March 11, 2015, 03:17:12 AM »
Bob
Would the part number be 7803777 ?
Camarocards
« Reply #11 on: March 11, 2015, 03:36:06 AM »
Bob
Bob
Yes. That is the number on the tag.
Bob
'68 SS L35 01D
big iron
« Reply #12 on: March 13, 2015, 12:17:12 AM »
Camaocards,
Ran a quick check in P&A's and found the following:
Oct  66  TW with Floor Shift   5699843
July 67   TW with Floor Shift  5699843
Nov 67  TW with Floor Shift   5699843
Nov 67        68 TW with Floor Shift   7803779
But if you look in a 69 P&A it will list 7803779 as being used in 67 and 68 as a service replacement part due to the fact the correct part 5699843 was out of production and no longer in GM stock.
I always try to use a P&A that is closest to the build date when the part was used. You may want to check the 67 #'s in a 66 P&A.
Hope this helps.
Bob
Camarocards
« Reply #13 on: March 13, 2015, 12:39:26 AM »
Bob,
Many thanks! Good info.
Here is what I've found so far:
TN 7803779 - '67 Floor shift with tilt wheel (Although Kurt indicated this may be "without" tilt wheel)
CN 7803777 - '68 Floor shift w/o tilt wheel (Was the same broadcast code used in '67??)
TK 7804300 - '69 Floor shift w/o tilt wheel
KB 7808154 - '69 Floor shift with tilt wheel
Thanks for your help.
Bob
Bob
'68 SS L35 01D
big iron
« Reply #14 on: March 13, 2015, 01:36:24 AM »
I believe 7803779 is a 68 Floor shift with tilt wheel. You will have to go to the 67 Nov. P&A to find this info but could be different in subsequent P&A's.
Bob C
Nov. 69 P&A snows 7803779 is for 67 68 Floor shift with tilt. This is a service replacement for the original 67 5698443.
