Author Topic: Most accurate 67 door sill moulding?  (Read 8941 times)
« on: February 27, 2015, 07:56:46 PM »
Hello list,
  Has anyone purchased door sill plates for a 67 recently or know of a close-to-accuracy as possible set with rivets?
Thank you in advance,
Jek9016
Re: Most accurate 67 door sill moulding?
« Reply #1 on: March 03, 2015, 10:36:48 PM »
Yes. Luttys chevy near pittsburg or classic industries should have them
Unfortunately i found most repro chrome and trim is low quality imported stuff
« Reply #2 on: March 04, 2015, 07:32:46 PM »
 Thank you, Jek. I'll look at those reproductions then. I'll post an orig to repro comparison and share in CRG.
« Reply #3 on: March 06, 2015, 11:07:16 PM »
Hard to make out from the pic but GM in the package.
Fisher Door Seals
« Reply #4 on: March 07, 2015, 12:37:08 AM »
Hi Darrell,
  Those looks like the NOS set I bought in the 80's and are still in the wrappers. The NOS ones do not have the rivets though  :(
I'll include the NOS plates in the side by side comparison when I get the reproductions.
Thanks for the reply!
« Reply #5 on: March 07, 2015, 12:38:15 AM »
Fisher Door Seals
Darrell, those are later service replacements (from the 80's on) that DO NOT have the rivets.  In the late 70's you could still purchase correct door sills but then they made a change that eliminated the rivets use. Here is a set purchased in 1979 that I'm using in our 68Z restoration. I'm sure repro's are making them with the rivet but not sure how accurate/correct they are. One could use these pictures to compare.
« Reply #6 on: March 07, 2015, 12:47:42 AM »
Thanks. I couldn't tell from the pic.
L78 steve
« Reply #7 on: March 09, 2015, 09:08:08 PM »
Ive seen somewhere that the rivits can be had and installed easily on the later style plates.
69 Z/28 Dover White. SOLD
« Reply #8 on: March 09, 2015, 09:57:10 PM »
Yup,...  http://chevynova.org/SillPlateRivetsInstall.html
69z28302
