Author Topic: What clip is being used for carb linkage.  (Read 11130 times)
Fred Mertz
« on: February 24, 2015, 12:06:12 AM »
I have a '69 with a 4053 carb and the 2 piece throttle rod that is 1/4" with a groove around it. What clip is being used to hold the linkage to the carb?  I'm having trouble finding something locally.
Thanks,  Dave
Re: What clip is being used for carb linkage.
« Reply #1 on: February 24, 2015, 12:41:42 AM »
Its an e clip.  I cant remember the size but just take your throttle rod to Lowes or Home Depot and find the correct size.
« Reply #2 on: February 24, 2015, 04:05:18 AM »
Retaining Pins
Used on grooved shafts, these are also known as hairpin clips. 18-8 stainless steel are corrosion resistant and may be mildly magnetic. Zinc-plated steel pins are rust-resistant
Ref. McMaster-Carr
Gramps69Z
  • 69 X33 D80
« Reply #3 on: February 24, 2015, 04:38:05 AM »
Think I bought mine at NAPA.
Captain John Wykoff
« Reply #4 on: February 24, 2015, 01:31:19 PM »
Retaining Pins
Ref. McMaster-Carr
For whatever reason the AIM shows 67 as being the cotter pin and 68-9 being an E-clip.  I always thought they were all e-clips..  But I havent looked at very many 7 Zs.
1969 #4 Ring
1967 #4 C. Pin
« Reply #5 on: February 26, 2015, 05:34:24 AM »
After reading up a bit your are right. < I always thought they were all e-clips>
I found a few cars with retainer style, must have been easier to find these vs the correct e-clips
zman1969
« Reply #6 on: March 10, 2015, 05:56:56 PM »
I had to use a clip like this as my e-clip came off (at the wrong time  :( ) due to lever being worn
Rich
69 RS/Z DZ302 Daytona bumble bee
69 T/A clone LS6/6sp
69 Nova SS 396
« Reply #7 on: March 11, 2015, 01:28:14 AM »
Retaining Pins
Ref. McMaster-Carr
1969 #4 Ring
1967 #4 C. Pin
Darrell, our 01B 68Z is cotter pin. It might have been changed sometime during the model year but no clip on ours.
« Reply #8 on: March 11, 2015, 12:42:14 PM »
That makes sense yours still had the cotter pin.  By my own ignorance I didnt read the revision notes on the 68 Z28 A3 page.  Shows lever dwg revised 12-1-67..  But further down shows new "A" items relocated @ 3-8-68..  So maybe it was later into production of 68 that the change was made.??.
Fred Mertz
« Reply #9 on: March 13, 2015, 03:24:23 AM »
I've decided to use the clip shown in "Zman1969"'s post.  Easy to install and remove.  I was able to find them locally .(Fastenal)
Thanks, Dave
