Welcome,
Guest
. Please
login
or
register
Did you miss your
activation email
1 Hour
1 Day
1 Week
1 Month
Forever
Home
Help
Search
Login
General Discussion
GM Big Block Aluminum Water Pump
« previous
next »
Print
Pages:
1
2
All
Author
Topic: GM Big Block Aluminum Water Pump (Read 14419 times)
dino67
Member
Re: GM Big Block Aluminum Water Pump
Reply #15 on:
February 13, 2015, 01:51:48 AM »
Thanks for the info on the 3975928 water pump. I've been using it on my 67 L78 for years also. It has the 5421 stamping too. I always wondered if it was an over the counter part or a factory part. Thanks for the input.
Logged
bergy
Member
Reply #16 on:
February 13, 2015, 12:02:01 PM »
I've had one of these pumps on the shelf for many years. Must be an early one with (no date). Question for you guys who are running these pumps - do you find that it improved cooling?
Logged
dino67
Member
Reply #17 on:
February 13, 2015, 08:11:08 PM »
I never had any over heating problems, but can't say it cools any better or worse than a cast water pump.
Logged
Hero Member
Reply #18 on:
February 13, 2015, 08:15:49 PM »
No real advantages other than weight. Cools the same in my application but I run an electric fan so....
Logged
twol78s
Member
Reply #19 on:
February 14, 2015, 04:47:13 AM »
The one on my 67 L78 seems to move coolant just fine. Never had the original cast iron pump on it, so I don't have anything to compare with, though.
Logged
Print
Pages:
1
2
All
« previous
next »
General Discussion
