Author Topic: 6 cyl engine decode  (Read 10320 times)
lykaneagle
6 cyl engine decode
« on: February 08, 2015, 05:27:39 PM »
I have myself a 67 camaro convertible 250.  I'm trying to find out if the inline 6 250 is original to the car.  No serial numbers were stamped on block so I can't confirm that way.  There is a code of 0810FM on the block.  The FM suffix is corrrect for a 67 camaro.  From what I understand, the 0810 means August 10th? .....but my trim tab shows my car 04A (first week of April).  So that doesn't add up unless the 0810 engine code is referring to 1966.  Is that possible?   The car has about 80K original miles so I can't imagine someone putting an entire new engine in this.......especially another period correct six.  Any input would be very appreciated.  Thanks much!
lykaneagle
Re: 6 cyl engine decode
« Reply #1 on: February 08, 2015, 05:57:54 PM »
Update:  Engine code is F0810FM
Thanks for the help and have a great day
« Reply #2 on: February 08, 2015, 06:25:43 PM »
Are you positive that IS the #, F0810FM? Because 0310 instead of 8 would put it right in the ballpark, so to speak. See if you can get the casting date off the block, and head, while you are at it. If we get enough info, we (CRG) will figure it out.
lykaneagle
« Reply #3 on: February 08, 2015, 07:08:34 PM »
best I can tell for casting # is 3859381 with GM 22 underneath.  Some of the 3's and 8's look similar but I think I have it correct.  The engine code is F0810FM NOT F0310FM
lykaneagle
« Reply #4 on: February 08, 2015, 07:26:24 PM »
Also found 877178 with either a "O" or a "C" at the end with GM29 underneath
« Reply #5 on: February 08, 2015, 08:09:27 PM »
3859381 is the casting number for the intake manifold, not the engine block.
« Reply #6 on: February 08, 2015, 08:13:16 PM »
Check again, the block casting number should be 3877178.  Also, what is the engine block casting date?
http://www.camaros.org/drivetrain.shtml#BlockCast
lykaneagle
« Reply #7 on: February 08, 2015, 08:25:06 PM »
Funny, there is no 3 in front of the 877178??  The casting date is G76....July 7, 66?   That's starting to make more sense.......
I wish I could get a picture up.  I've set my camera to smallest resolution but the file's still too big.
« Reply #8 on: February 08, 2015, 08:26:48 PM »
What trans is in the car?
lykaneagle
« Reply #9 on: February 08, 2015, 08:36:09 PM »
When I got the car the motor had been swapped to a 350 and a 700R4 tranny.  I have the original(?) inline 250 and powerglide tranny. I think I figured out the pic problem.  If so, i'll post....
lykaneagle
« Reply #10 on: February 08, 2015, 08:39:57 PM »
stamp..
« Reply #11 on: February 09, 2015, 04:06:59 AM »
I think that's the original engine. I see two other March cars with Aug 66 FM blocks - could have been pushed back in the corner or.....
lykaneagle
« Reply #12 on: February 09, 2015, 03:43:43 PM »
Hey that's good news!  In twenty years I just may put her back to a numbers matching sweetheart.  There weren't too many 6cyl convertibles made.....may be the "thing" someday.   Thanks so much for your help!  This site is the best
