Moderator needs to move this to maintenance. I have changed oil without having to remove any of mentioned items. You may need a swivel socket to gain access to rear bolts. While pan is off, you should dimple the holes with a ball pean hammer to restore holes to being flat with surface. Most leaks occur from overtightening the pan. I believe spec, without looking up, is around 25 inch pounds or about what would be achieved using a 1/4 inch ratchet.
