Author Topic: Battery Ground Cable  (Read 7103 times)
dannystarr
« on: February 02, 2015, 03:49:40 AM »
Anybody know the application for this part number.. 6286165P Spring Clip Terminal Ground cable... Danny
Re: Battery Ground Cable
« Reply #1 on: February 02, 2015, 05:25:58 AM »
Danny, there might be other applications, but here's a start...
http://www.gmpartswiki.com/getpage?pageid=77280
http://www.gmpartswiki.com/getpage?pageid=80074
dannystarr
« Reply #2 on: February 02, 2015, 06:52:50 AM »
Thanx, I found one at HB City with the same number but it has a YM after it. Wonder what the "P" is, and what the "YM" stands for...? It says it is for a '67 Camaro, and pre August 27th '68 Camaro. So I am starting to think this is incorrect for my May/June '68... D
« Reply #3 on: February 03, 2015, 12:05:52 PM »
The YM would correspond with the broadcast code printed on the build sheet.
I'm not certain about the P, best guess .... P -  Positive
« Reply #4 on: February 03, 2015, 05:20:17 PM »
YM? I've never seen that code on a 67.
BW = SB w/ R59 in 67.
dannystarr
« Reply #5 on: February 04, 2015, 02:27:35 AM »
I just realized that both of my cables appear to be original, they have just had the ends cut? Are these numbers correct for my May '68 Camaro? ... D
   Positive = 6290590BV
   Negative = 2986167EH
« Reply #6 on: February 04, 2015, 03:12:58 AM »
Probably Danny.  My '69 P&A list the service replacement cables as...
+ 6290591
-  2985652
« Reply #7 on: February 04, 2015, 06:24:38 AM »
Quite common to cut the spring ring off and use a clamp type with cross bolt. It is something to check on some of the less molested cars just to see if they are the originals. I sometimes forget to check them unless the spring ring is still there.
dannystarr
« Reply #8 on: February 04, 2015, 05:02:27 PM »
I have to check how long they are, as I might try to repair them in the future. I have lead, ladle, torch for when we used to do lead and oakum joints in waste lines and rain water leaders. I can find cheaper versions of the same era so the spring ring matches, and cut the cable off or try to pull them out so I don't lose any inches. Then drill it bigger put the end in and pour in the lead. Problem is, I think they may have been cut and cleaned and stripped to many times?? .. Danny
« Reply #9 on: February 04, 2015, 10:55:04 PM »
Danny, if it helps my '69 P&A list the service replacement cables as being this long...
+ 6290591:  48" center to center holes
-  2985652:  29" center to center holes
1968 Z28
« Reply #10 on: February 05, 2015, 01:09:05 AM »
Danny.....FYI, my Z28 has the same numbers on the cables.
     Measurements
       Positive - 6290590BV  (50 " - center of battery terminal to the starter terminal bend)
       Negative - 2986867EH  (22 1/8" - center of battery terminal to the center of the starter terminal)
Jerry G.
Z28-1968-07C-Norwood
2nd. Owner, 38,000 miles
