Author Topic: 69 Wheel opening mouldings  (Read 7023 times)
L78 steve
« on: January 26, 2015, 03:49:36 PM »
The 69 front wheel opening moldings 3953635 and 36 do not have the holes drilled for the fender bolts? Is this so?
Thanks, Steve.
69 Z/28 Dover White. SOLD
BillOhio
    • photobucket
Re: 69 Wheel opening mouldings
« Reply #1 on: January 26, 2015, 06:53:10 PM »
no holes
1968 RS 327 4 speed
Stingr69
« Reply #2 on: January 30, 2015, 12:46:21 AM »
The original front wheel well moulding has the holes in it for the fender bolts.  I don't know why they would not still come that way?  That is how they are attached.
BillOhio
    • photobucket
« Reply #3 on: January 30, 2015, 01:40:14 AM »
I was thinking small screw holes. Not sure on fender bolts. I tried to look but no luck. Wasn't there a second part number on these that were different by holes in them from the originals?
1968 RS 327 4 speed
Camarocards
« Reply #4 on: January 30, 2015, 03:09:11 AM »
The NOS moldings I have has holes in them. They're for 67-68 though.
Bob
Bob
'68 SS L35 01D
« Reply #5 on: January 30, 2015, 06:38:10 AM »
69 have the fender bolt holes. Some repros did not. I don't know about what is currently out there...
Stingr69
« Reply #6 on: January 30, 2015, 04:33:51 PM »
Rear wheel well moldings have small holes for the attaching screws.  The screws should be included.
The fronts did not need screws due to the large fender bolts holding them in place.
jacmac
« Reply #7 on: January 30, 2015, 11:32:12 PM »
I believe there should be 2 screws for the front fender extension
rszmjt
« Reply #8 on: February 17, 2015, 03:41:45 PM »
Some Later Issue GM front wheel well mouldings came with no holes for some reason, a pain to drill unless you have originals to use as a pattern.
L78 steve
« Reply #9 on: February 17, 2015, 03:58:42 PM »
We stamped the holes and used a spare set of fenders for the pattern.
