Welcome,
Guest
. Please
login
or
register
Did you miss your
activation email
1 Hour
1 Day
1 Week
1 Month
Forever
Home
Help
Search
Login
Decoding/Numbers
Identifying this big block
« previous
next »
Print
Pages: [
1
Author
Topic: Identifying this big block (Read 4589 times)
clean68rs
Member
on:
January 12, 2015, 02:21:29 AM »
I have a 454 big block here and would like to know more about it here are some numbers. casting #14015445 also on left side #4234166802. Above where the oil filter installs this is cast in the block k14 Thanks for any help.
445
Hi Perform
Pass
Tweet
Logged
Hero Member
Re: Identifying this big block
Reply #1 on:
January 12, 2015, 12:34:04 PM »
http://www.mortec.com/bbc.htm
14015445...454.......78-90...2 or 4 bolt
Logged
CRG Coordinator
Reply #2 on:
January 12, 2015, 06:30:35 PM »
Not sure what more we can tell you.
http://www.camaros.net/forums/showthread.php?t=321002
Logged
clean68rs
Member
Reply #3 on:
January 14, 2015, 12:52:13 AM »
Thanks for the help. I know more now then when I started.
Logged
CRG Member
Reply #4 on:
January 14, 2015, 05:52:17 PM »
To really know what you have you will need to take it apart to see what cam it has and which crankshaft it has. Also take a valve cover off to see which heads it has.
Logged
Bryon
/ 1968 Camaro SS 396 coupe - now old school 468 big block
Print
Pages: [
1
« previous
next »
Decoding/Numbers
