Author Topic: 68 Backup Switch Harness Clips  (Read 3950 times)
blackss69
« on: December 27, 2014, 09:30:44 PM »
I am looking for a picture (maybe part number, tracing, etc) of the clip shown in the 1968 AIM M20 A7.  This is the clip for the backup lamp harness that is installed in the upper position with a bell housing bolt (3/8 diameter).  It does not have a part number in the AIM so I assume it was installed at the engine plant.
I have the lower clip that mounts to the lower transmission mount (shown as item 2 p/n 2404001) and it has a 1/2 diameter hole for the larger transmission bolt.  The harness is retained with these clamps (5/16 OD).
A picture, drawing (tracing) or any information would be helpful.
Thanks and Happy New Years
Re: 68 Backup Switch Harness Clips
« Reply #1 on: December 28, 2014, 01:23:12 AM »
Here you go...
« Reply #2 on: January 01, 2015, 05:18:10 AM »
Wow Paul, that is one great picture! LOL  ;D
