Author Topic: cracked dash?  (Read 6167 times)
1968z28
cracked dash?
« on: December 17, 2014, 03:59:25 PM »
got a crack in my 68 dash.  where is best place to get replacement?  or can a crack be fixed and not show?  the dash seems brittle.
thanks
lakeholme
  • 68-12D L30/M35
Re: cracked dash?
« Reply #1 on: December 17, 2014, 10:15:27 PM »
I assume you mean the pad, since you described it as brittle.
Yes, a crack in the dash pad can be repaired, but unless it is in a vey inconspicuous place, it will show.  My 68 dash was brittle and cracking on both ends right at the top. The more I tried to repair it, the more cracks grew and showed.  Last year when I had some interior work done, I decided it was time to replace it.
I'm going to let some of the guys that do multiple restorations tell you where to buy....
Good luck in whatever you decide!  ;D
Re: cracked dash?
« Reply #2 on: December 18, 2014, 12:31:39 AM »
I've never personally used them, but you can try Just Dashes in CA, www.justdashes.com , (800)247-3274. Been around a pretty good while -
Re: cracked dash?
« Reply #3 on: December 22, 2014, 02:21:12 AM »
Just Dashes completed dashes look over stuffed or just down out fat. Best I have seen for 68 dashes hands down at a very affordable price is Al Knoch Interiors. When they first started doing them a few years ago it was only $125. Not sure what they are charging currently!
JKZ27
Re: cracked dash?
« Reply #4 on: February 12, 2015, 03:00:05 PM »
Sent my 68 dash to Al Knoch in 2013 and it turned out great. Cost $185 plus shipping. Turn around was pretty quick too.
John
68 RS Ash/Ivy Gold 327EFI M20
