Author Topic: exhaust manifold torque small block  (Read 6815 times)
BillOhio
    • photobucket
« on: December 10, 2014, 08:14:20 PM »
I have searched and looked in assembly manual and not much luck. I did see center bolts 35 outside bolts 15. Is this without gaskets? With gaskets any different? I am using french locks and no gaskets.
1968 RS 327 4 speed
Re: exhaust manifold torque small block
« Reply #1 on: December 10, 2014, 09:49:34 PM »
My 1968 Chevrolet Chassis Service Manual (ST 130-68) says 20 lb. ft. for the exhaust manifold bolts (3/8 - 16).  Same specification for all V8s (small & big blocks).
1968 Z28
« Reply #2 on: December 10, 2014, 11:36:08 PM »
I think I've seen in a Haynes manual that the readings should be.....20 ft/lbs on the outer and 30 ft/lbs on the inner.
Jerry G.
Z28-1968-07C-Norwood
2nd. Owner, 38,000 miles
Stingr69
« Reply #3 on: December 11, 2014, 02:54:47 PM »
Chilton says that too.  I would not change the torque when using gaskets.
-Mark.
BillOhio
    • photobucket
« Reply #4 on: December 11, 2014, 04:29:47 PM »
Thanks guys
1968 RS 327 4 speed
« Reply #5 on: December 11, 2014, 10:38:48 PM »
I would not use gaskets, the General didn't.
BillOhio
    • photobucket
« Reply #6 on: December 12, 2014, 01:04:21 AM »
I am going to try no gaskets. One less thing to go wrong!
1968 RS 327 4 speed
« Reply #7 on: December 12, 2014, 03:57:58 PM »
And if you expect to be able to remove the exhaust manifold bolts at some later date, use a film of hi-temp anti-sieze on them when you install them.  :)
« Reply #8 on: December 16, 2014, 04:41:00 AM »
I use hi-temp anti-sieze on every exhaust clamp and bolt on every car I own. Makes working on the exhaust so much easier later.
