Author Topic: Service Engines (CE coded)  (Read 111381 times)
Re: Service Engines (CE coded)
« Reply #30 on: December 15, 2014, 08:54:16 PM »
Thanks Darrell!
Just one thing, could you merge columns F and G to read 'oil pan flange stamp' or whatever makes sense to members please? Some (maybe all?) CE blocks have an assembly date stamped down there on the gasket surface.
« Reply #31 on: December 15, 2014, 09:12:36 PM »
Done.
« Reply #32 on: December 16, 2014, 02:19:37 AM »
Thank you Sir!
red69
« Reply #33 on: December 17, 2014, 12:46:35 AM »
I have a 1969 302 that I acquired in 1975. CE# was decked off years ago, this thread got me interested so I checked it out today. The pad under the starter is stamped 01 9V, block was cast A179. I noticed up front on the right side lower pad in front of the fuel pump it is stamped Z and 5 in what appears to be the same font as under the block., not together they in different spots. Probably not anything, but I thought it was strange.
« Reply #34 on: December 17, 2014, 12:54:39 AM »
01 9V is likely January of 1969, Flint - based on the casting date of January 17, 1969.
What is the casting number?
red69
« Reply #35 on: December 18, 2014, 01:05:24 AM »
What is the casting number?3956618
Kelley W King
« Reply #36 on: January 20, 2015, 07:03:48 PM »
If you are still keeping up mine is
CE974183 cast F 11 69 block 3969854  car is a 12A
69 SS L78
67 SS Chevelle
64 Corvette
66 GTO Tiger Gold
77 Trans Am Special Edition
« Reply #37 on: June 11, 2015, 07:40:55 PM »
If you or anyone else would like to share data, it would be AWESOME and greatly appreciated.  We need as many data points as we can get.
What would be best is
1. Picture of the stamped information on the pad.
2. Block casting number
3. Block casting date
Thanks!
1. CE9B36978
2. 3970010
3. H 7 9
« Reply #38 on: June 14, 2015, 04:37:38 AM »
Thanks!
1. CE831140 (photo below)
2. 3914678
3. I 25 7
« Reply #39 on: June 14, 2015, 04:43:00 AM »
Thanks!
1. CE9A43523 (photo below)
2. 3956618
3. B 20 9
BSMIT59
« Reply #40 on: June 15, 2015, 12:44:29 AM »
What would be best is:
I have a 3892657 casting  engine code CE8 235  12  date stamp H 187.  Above the oil filter it is stamped 3 groups of numbers. Top tp bottom  944  657  76N.
I believe it is a 350 replacement for 67 SS but have no way to verify.
Thanks!
« Last Edit: June 15, 2015, 04:19:12 AM by KurtS »
Barry     Old guy but still learning.....
Unrestored 67 barn find
67 SS 350 in process  ( in paint booth now)
Looking for 7N243673 to reunite V0320MO block and crank
« Reply #41 on: June 16, 2015, 06:01:40 PM »
Sorry, I have not been keeping up.  Thanks everyone for posting data!
« Reply #42 on: June 30, 2015, 07:00:01 AM »
Thanks!
1. CE922510 (photo below)
2. 3914678
3. G 11 8
Fred Mertz
« Reply #43 on: June 30, 2015, 09:15:38 PM »
It's been stated on this forum that '68 Z/28 engines were all 2 bolt mains.  In '71 I bought a '68 Z/28 that had a replacement "CE" motor.  In '73 I rebuilt that "CE" motor.  It was indeed a 302 Z/28 motor.  It had the correct crank , pistons,  rods and damper.  The damper did not have an offset keyway.It was also a 4 bolt main block.  The block was a 3970010 casting.  If the engine was replaced during the '69 model year would this explain the 4 bolt mains?
Does this make sense?
« Reply #44 on: July 01, 2015, 01:59:10 AM »
Makes sense to me Fred...  it would have to be a 69 or later block for an 010 casting.
