Author Topic: Service Engines (CE coded)  (Read 111304 times)
Re: Service Engines (CE coded)
« Reply #120 on: January 01, 2020, 04:58:08 PM »
Note here from the Chevrolet Dealer Service Information Bulletin dated September 29, 1969.  It is the same wording used in the CRG engine section for CE engine coding.
The last five digits specify the service replacement unit sequence number.
There was discussion a while back that this was a "serial number".  I did not agree with that wording, and I still don't agree with it.
« Reply #121 on: January 01, 2020, 10:58:39 PM »
The right hand side column header in the extract you posted is 'Serial Sequence', the sequence (range) of serial numbers assigned to each engine plant.
« Reply #122 on: January 02, 2020, 12:08:10 AM »
The wording "serial number" to me suggests something is trackable forever.  Obviously that is not what happened with these assemblies, or we would have tons of dealer replacement paperwork matching up with these blocks and transmissions.
I have not found any documentation that uses just the two words "serial number" to refer to them.
It is a number. It is serial. But not a serial number.
We may have to agree to disagree.
« Last Edit: January 03, 2020, 03:05:41 AM by bcmiller »
« Reply #123 on: January 02, 2020, 05:10:02 AM »
Disagree away. But not sure why this seems to be so important to make a distinction. Trackable or not, the bulletin set out a sequence of serial numbers that were part of the CE stamp.
« Reply #124 on: January 02, 2020, 02:37:37 PM »
Funny!   Bryon doesn't think it's a serial number..  even though they were 'built serially', and have a unique number assigned to each part which is a part of that 'series' of numbers.   Even the original GM document refers to them as 'serial numbers', noting that the state of Georgia required unique 'serial numbers' for each of these major parts/assemblies.
Trackable?  I'm sure that GM 'tracked' the serial numbers during the period it was critical to them (the warrantee period), and perhaps after.  Since the purpose of the entire CE/CT documentation and serializing was for 'theft' purposes, it was probably up to the owners of the vehicles to maintain records of warranty replacement parts installed on their cars to be effective for that purpose; at least it's true for that today since we apparently don't have access to the original GM 'trackable' information.
Attached below is a copy of the original GM internal letter creating this system which refers to the identification numbers as 'serial numbers'.
Kelley W King
« Reply #125 on: January 02, 2020, 09:03:10 PM »
With all respect to Bryon I would call it a serial number because there should be no two alike even if there is not a way to track them. "part numbers" can represent thousands of the same, but serial numbers should one of one.
69 SS L78
67 SS Chevelle
64 Corvette
66 GTO Tiger Gold
77 Trans Am Special Edition
BSMIT59
« Reply #126 on: January 03, 2020, 01:55:42 AM »
Has anyone seen a previous year casting style block used as a warranty block for the next model year? My 2657 casting, which was for 1967 model year, is stamped as a CE8XXXXX, with an assembly date stamped on the starter area of 08 7 F...... seems unusual to have been assembled that early for the 68 model year. Did they use whatever castings were leftover?
Barry     Old guy but still learning.....
Unrestored 67 barn find
67 SS 350 in process  ( in paint booth now)
Looking for 7N243673 to reunite V0320MO block and crank
« Reply #127 on: January 03, 2020, 02:59:23 AM »
Barry yours was assembled at Flint in August of 1967, for the 1968 model year. We don’t know when in the month it was assembled. The older castings were probably being used up as the new castings started. There is always some overlap, which varies.
What is the casting date?
66shelby427
« Reply #128 on: May 25, 2021, 12:43:16 AM »
Updated:
BB/SB   Block Casting   Casting Date   Pad Stamp   Oil Pan Flange Stamp   Note(s)
Cast 1967
BB                      3916323        F 6 7      CE850140       T087
BB                      3916323         F 6 7         CE850154           T087
BB                      3916323        J 8 7      CE853643       T0107
Cast 1968
SB                      3914678        D 16 8      CE922528
SB                      3959512        J 10 8      CE089910
SB                       3932386                  J 22 8              CE936524
SB                       3959512                  K 21 8             CE944015
SB                      3959512        K 29 8      CE946309
Cast 1969
SB                      3956618        A 9 9      CE9A24288
SB                      3956618        A 30 9      CE9A32634
SB                      3970010        E 12 9      CE9A98666
BB                      3969854        F 11 9      CE973962
BB                      3969854        H 30 9      CE070400          T099                  Also first stamped T0916KE
SB                      3970010        I 18 9       CE9B44296                                  warranty repl. for  V0725HX orig eng.
BB                      3969854        J 14 9      CE075672
SB                      3970010        L 8 9      C15408U                         (anomoly; possibly non-factory stamp?)
Cast 1970
SB                      3970010        C 28 0      CE0A48264
SB                      3970010        E 23 0      CE0B00122
SB                      3970010        I 2 0        CE1A94176
SB                      3970010        L 29 0      CEA129749                    (no typo, A before 1, photo available)
Cast 1972
SB                      3970010        A 10 2      CE221365
BB                      3999289         F 21 72      CE264155
BB                      3999290        J 23 72      CE361351
Cast 1974
SB                      3970010        B 12 4        CE3A97396                    (cast 74 but stamped for 73 MY?)
SB                      3970010        F 20 4      CE431334
Table formatting is a bit misaligned, but other members please feel free to add your data to it, by hitting 'quote' and then inserting in the appropriate date order. Thanks!
hihorse
« Reply #129 on: May 29, 2021, 02:50:20 AM »
CE866921 from the best that I can tell...
most likely CE966921
