Author Topic: Original ball joint amd tie rod numbers  (Read 5761 times)
Knappy
« on: November 22, 2014, 03:51:26 PM »
Has anyone done any research on first gen. Camaro front end part numbers?  I'm trying to piece together the front end of my
67 Z-28 but cannot find the original part numbers to the ball joints and tie rods.  I have come up with 4 or 5 different numbers
depending who I talk to.  I would be great to have a parts list for the complete front ends.
69 COPO Camaro
67 Z-28
69 Z-28
Re: Original ball joint amd tie rod numbers
« Reply #1 on: November 24, 2014, 07:59:40 PM »
JohnZ answered your question:
http://www.camaros.net/forums/showthread.php?t=312233
> They're in UPC 3 in your Assembly Manual.
And here is a your AIM.
http://www.camaros.org/forum/index.php?topic=9433.0
Knappy
« Reply #2 on: November 25, 2014, 02:49:42 AM »
The only number in the 67 assembly manual is 9740569 for the upper ball joint with a 7800908 option for an upper ball joint.
There is not a number for the lower ball joint as well as the tie rods and idler arm.  The lower control arm was an assembly as well as the relay & tie rod assembly.  The individual part numbers are not given in the assembly manual.  I am looking for the original assembly line part numbers for the upper and lower ball joints, tie rods and tie rod sleeves, and idler arm.
69 COPO Camaro
67 Z-28
69 Z-28
« Reply #3 on: November 25, 2014, 05:32:31 PM »
« Reply #4 on: November 25, 2014, 11:30:06 PM »
We had boxes of NOS service suspension parts for our '67 Z/28 project of many years ago and none of the ball joints or tie rods looked same as production. Two different worlds, different suppliers.
