Author Topic: 69z rag joint  (Read 6282 times)
69ZX77MP
69z rag joint
« on: November 12, 2014, 01:09:26 AM »
does anyone have a picture of an original power steering rag joint I have two different ones want use the correct one thank you
1969 Z28 X77 Lemans Blue 03D
BillOhio
    • photobucket
Re: 69z rag joint
« Reply #1 on: November 12, 2014, 03:15:58 AM »
I have the other side if you need it. Bolt had a lock tight material
1968 RS 327 4 speed
69ZX77MP
Re: 69z rag joint
« Reply #2 on: November 13, 2014, 12:33:10 AM »
Thanks if you could post other side that would be great
BillOhio
    • photobucket
Re: 69z rag joint
« Reply #3 on: November 13, 2014, 12:42:06 AM »
Other side. I didn't add any of the marks. Just cleaned it
1968 RS 327 4 speed
69ZX77MP
Re: 69z rag joint
« Reply #4 on: November 13, 2014, 12:54:02 AM »
Thanks mine doesn't look like yours I guess I have to keep on looking thanks again
Re: 69z rag joint
« Reply #5 on: November 13, 2014, 01:06:22 AM »
 Isn't there a difference between manual vs. power steering rag joints for '69? I thought the spline area varied between the two.
69ZX...what does yours look like now?
69ZX77MP
Re: 69z rag joint
« Reply #6 on: November 13, 2014, 01:59:00 AM »
This is what I have
Re: 69z rag joint
« Reply #7 on: November 13, 2014, 02:53:50 AM »
 I think you are fine with the power steering joint you have. I just checked a '68 power steering box off a Camaro in the shed and it has the exact one you have including the ground wire and the area with no splines towards the center. The one Bill posted looks like a manual joint, which has the area with no splines towards the side. I also have a manual steering joint and its the same as Bill's.
BillOhio
    • photobucket
Re: 69z rag joint
« Reply #8 on: November 13, 2014, 03:39:30 AM »
Can't believe I missed the power steering part! Very sorry. Mine is manual
1968 RS 327 4 speed
69ZX77MP
Re: 69z rag joint
« Reply #9 on: November 13, 2014, 02:09:49 PM »
Thanks Bill ,Mike for your feedback this site is awsome
