Author Topic: 67 350 - VIN 7N127127, MS code, plus matching Muncie 4-sp  (Read 9821 times)
RSSSFanatic
« on: October 25, 2014, 02:27:14 PM »
I have a complete MS coded 350 from a 1967 SS, included all tin besides valve covers, heads, intake, distributor, water pump.  Needs complete rebuild, has already been bored .060.  Also have matching Muncie 4-speed transmission in good shape, with VIN stamped on it.
Don't have date codes on block - engine is buried under stuff right now, but recall it being an early build, late Oct/ early Nov.
BSMIT59
Re: 67 350 - VIN 7N127127, MS code, plus matching Muncie 4-sp
« Reply #1 on: November 01, 2014, 12:54:49 PM »
I'm building a 67 SS now that I bought with no drivetrain. I would be interested in the whole outfit if priced right. Not having any luck on finding my original. It is a December build.
Barry     Old guy but still learning.....
Unrestored 67 barn find
67 SS 350 in process  ( in paint booth now)
Looking for 7N243673 to reunite V0320MO block and crank
RSSSFanatic
« Reply #2 on: November 01, 2014, 06:37:03 PM »
Where are you located?  I'll be ouut there working in the garage this weekend, and I will try to dig down to it and get you some casting dates.
What is the exact build date on your trim tag?
I did have the tranny handy, and it is stamped P7R17, with the VIN stamped on it.  It is a nice, unmolested trans, with the original part # tag and all the original bolts and keepers in place.  I doubt if it has ever been apart, and the gear teeth and synchros lead me to believe the mileage on it is fairly low.
I'll try to get out there and post up some pictures.  Based on that, if you are still interested we can see if we can get together on a fair price for everything.
I also have a 657 block that I had been planning to use for my 67.  My car is a 12C build, and the other block is a  casting K216 date.  Block stamping is VII23YW. That one is standard bore, and the cylinder walls are rusty and the pistons are froze in the bores, but I think a machine shop would be able to get it apart and the bores would probably clean up at .030 or .040.
Tom
BSMIT59
« Reply #3 on: November 03, 2014, 12:41:28 AM »
Central ohio. Mine is a 12D build.
« Reply #4 on: November 09, 2014, 06:00:42 AM »
Engine date is V0908MS. Had to use my x-ray vision to see thru the stuff piled on it. :)
