Author Topic: Bumper Jack -- Original color  (Read 9364 times)
camaroman1969
« on: October 21, 2014, 04:23:58 PM »
Hey Guys....Is the color for the jack hook and jack base plate light gray?  If so, where can a guy find a spray can of it??  thanks again.......Don
Re: Bumper Jack -- Original color
« Reply #1 on: October 21, 2014, 04:30:32 PM »
Yes, it was light gray, but I can't tell you a paint code..  I was unable to find a proper original factory reference when I repainted mine..  I just found one that seemed a close match to an original jack/base that I had...?
69 Zee
« Reply #2 on: October 22, 2014, 01:42:01 AM »
This question seemed to of been asked several times over on Team Camaro in the "Restoration Center" but had very little response.  It appears to of been a light gray.
www.camaros.net/forums/showthread.php?t=201879
Darrell
MyRed67
  • SZZLN 67
« Reply #3 on: October 22, 2014, 03:18:19 AM »
I used Rustoleum Machine Gray for both Jack and Shocks.  I was not concerned with "spot on" originality, but wanted to be close.  I forget where but it was recommended somewhere.  My shocks aren't even spiral shocks, they're Monroe Gas shocks.  But at a glance they look right. My cars a driver, I read somewhere here on a post that I wouldn't be happy with Spiral shocks on a driver.
1967 Camaro  LOS  11A
Original Engine   Z - Tribute
Mike C.    NW - Illinois
« Reply #4 on: October 22, 2014, 04:11:11 AM »
Don't laugh, but this one worked for me. I used it on the backsides of the SS1 Rally wheels on my '70 LS5 - it's a close match to "putty gray", which is the recommended color for shocks and jack bodies from several sources. Cap color is pretty close to finished color - cheap enough to risk a can to try, IMO -
« Reply #5 on: October 22, 2014, 11:37:33 AM »
Krylon’s Dove Grey is a good choice and noted to be close. "Rustoleum sells a "High Performance" Industrial paint at Hardware store chains. Their color #7581 - Light Gray is a very close match to the original base color. The UPC code is 020066758189." The Rustoleum info came from past comments I saved from somewhere but have not tried.
« Reply #6 on: October 22, 2014, 01:23:41 PM »
I went and looked at the paint I used..  which was the closest color/shade to my original jack... and it was 'Rustoleum Gloss Arctic Gray'..  purchased at Lowes I think..
« Reply #7 on: October 22, 2014, 10:26:56 PM »
Did your jack parts appear to be gloss or was it just the shade that was close? Never saw anything that would indicate gloss on those prior!
camaroman1969
« Reply #8 on: October 22, 2014, 11:03:40 PM »
Steve and all other's who commented on the jack paint color, thank you!!!!!  This info will help.    Don
BillOhio
    • photobucket
« Reply #9 on: September 06, 2015, 01:40:37 AM »
I am looking for the color of the jack for a buddy. I have mine and it is not gloss. It appears to be lighter than the shocks also. Probably not made the same place so I would doubt the paint was the same?
1968 RS 327 4 speed
« Reply #10 on: September 07, 2015, 12:55:29 AM »
Chick,  sorry to be so slow in responding (not sure how I missed your question a year ago).. :)     but as I recall, the color/shade was what I was looking for...  don't think I was even thinking 'gloss'... and not sure how much gloss was left on my jack base after almost 40 yrs.. :)  (You can use some extra fine steel wool to 'reduce gloss' if desired....)
