Author Topic: Speedo gear reduction  (Read 12243 times)
L78 steve
« on: October 20, 2014, 02:50:11 AM »
Would a 67 Camaro, 4.10 geared use the external speedo cable reducer?
My 69Z has the red plastic gear for 4.10 but no external reduction.
69 Z/28 Dover White. SOLD
L78 steve
Re: Speedo gear reduction
« Reply #1 on: October 23, 2014, 06:17:53 PM »
Anyone?
Kelley W King
« Reply #2 on: October 23, 2014, 06:38:29 PM »
I have never seen a car come with that device. Why? they have gears for all factory ratios. I think that device would be for non factory gears like 586 or 614?
69 SS L78
67 SS Chevelle
64 Corvette
66 GTO Tiger Gold
77 Trans Am Special Edition
« Reply #3 on: October 23, 2014, 06:53:32 PM »
It depended on the trans and rear ratio along with tire size whether or not it got the reducer. The M20 4.10 69 Z with low miles I restored did not have a reducer.
JohnKY
« Reply #4 on: October 23, 2014, 08:18:02 PM »
If the car originally had 14" tires, it would use an adapter, with 4:10 gears.
L78 steve
« Reply #5 on: October 23, 2014, 08:36:35 PM »
This is what I thought. My 67 has 14" tires with 4.10 and none of the avail. trans. gears are correct. the 70 LS6 4.10 used this adaptor.
x66 714
« Reply #6 on: October 24, 2014, 03:00:22 AM »
1968 Z/28 with 4:56 gears had one from the factory. Not like those pictured...Joe
L78 steve
« Reply #7 on: October 24, 2014, 01:37:36 PM »
Was it a Stewart Warner 666 ? should look similar to above pic.
JohnKY
« Reply #8 on: October 24, 2014, 02:55:23 PM »
Both the 67 (4spd., 14" tire. 4:10) and the 68 Z28 (4spd., 15" tire, 4:56) would have used the same adapter. Part #6476735 with a gear ratio of .8235.
L78 steve
« Reply #9 on: October 24, 2014, 05:26:10 PM »
Thank you for the info.
luv2sixty9
« Reply #10 on: October 31, 2014, 12:15:40 PM »
I have a 67 Z28 with factory 488 gears and it has an adapter. If my memory serves me correctly I believe its also 6476735 and my car has the 15x6 / 15" tires
1967 Z/28 Butternut Yellow
1969 Z/28 Rally Green
1969 RS Z/28 Lemans Blue
1969 RS Z/28 Olympic Gold
1969 RS SS Pace Car
2010 Aqua Blue 2SS RS
L78 steve
« Reply #11 on: November 03, 2014, 05:12:15 PM »
I installed the adaptor in the 67. There is barley room for the cable due to the 396 being shoved over another 3/4" . Hope the sharp radius in the cable is OK. I will take a pic. Anyone else with this set-up?
« Reply #12 on: November 05, 2014, 08:10:40 PM »
This has been discussed before.
As I recall, there were different Muncies with two different driven gears. The one version was for the steeper rear gears and could be used with non-steep gears with the adaptor.
L78 steve
« Reply #13 on: November 12, 2014, 05:43:05 PM »
My 69Z 4:10 Rear also no reducer. It uses the 25 tooth natural color gear.
Rufcar
« Reply #14 on: November 26, 2014, 06:14:37 PM »
I know I am late to the party but what I did was get 3 or 4 different color (teeth count) speedo gears then I used my GPS to get my actual MPH and Id change until I got to the correct speed on the GPS and if the speedometer is off a bit after that, just make a note of how far off one way or the other for you record.
I started by counting the teeth and then ordering the gear I thought Id need and this took way too long as the gears are not that expensive. It def saved me a ton of time. I got some gears off ebay the others at a GN dealer.
