Author Topic: GM Lug Nuts  (Read 3458 times)
camaroman1969
GM Lug Nuts
« on: October 18, 2014, 11:33:56 PM »
Calling Camaro guru's again.  I've seen lug nuts on ebay for sale with a stamping of letters of: "DMC".  Is this correct for a 1969 Camaro??  I've seen some with 3 little triangles stamped on them.  Did GM have numerous nut vendors for these bolts???   Any advise will aid me in purchasing correct lug nuts for my Camaro.  Thanks guys....Don
Re: GM Lug Nuts
« Reply #1 on: October 19, 2014, 12:20:47 AM »
It was my understanding that there were a handful of lug nuts used. The DMC ones are acceptable, I have seen the triangle ones but I cannot remember the manufacturer of those or if they were a original supplier. I think the other ones I have seen have a waffle pattern on the face of them, which I am guessing is original from the machine in the factory that put them on.
Re: GM Lug Nuts
« Reply #2 on: October 19, 2014, 03:14:50 PM »
GM used half a MILLION lug nuts every single day, from MANY vendors; it would be difficult to say that any vendor was exclusive to any given plant at any given time. The multiple-spindle nutrunners that installed the lug nuts didn't mark the nuts in any way - any marking or surface texture on the nut came from the manufacturer.
Re: GM Lug Nuts
« Reply #3 on: October 19, 2014, 03:45:09 PM »
So are the triangle ones also considered original?
