Author Topic: Vin for data base  (Read 23410 times)
Rsss396
Vin for data base
« on: October 13, 2014, 03:13:03 AM »
Vin124378N378371
From what I can tell its a orig rsss396 4 spd M21 car. Manual steering, Power 4 piston front calipers, deluxe interior, no spoiler no console or gauges.
Green exterior black interior
Rsss396
Re: Vin for data base
« Reply #1 on: October 13, 2014, 10:49:06 AM »
« Reply #2 on: October 13, 2014, 12:05:14 PM »
Vin124378N378371
How did you come by this information?
Rsss396
« Reply #3 on: October 13, 2014, 12:13:02 PM »
I have owned this car since 1988, orig motor was missing when I bought it. But I am 100% sure it was a big block car orig from the factory, 90% sure the trans and rear end are orig to the car.
« Reply #4 on: October 16, 2014, 12:25:35 AM »
M21? Are you sure?
Do you know the trans or axle codes?
Thanks!
Rsss396
« Reply #5 on: October 16, 2014, 02:10:52 PM »
Car is in storage I will have to try and get the both the codes off the trans and axle, I have a spare muncie and I am almost sure when I did research on what I had in the car and what I had for a spare, one was a M20 and the other was a M21.
I will update as soon as I can
« Reply #6 on: October 27, 2014, 07:30:39 PM »
Thanks and will be watching for the update.
Rsss396
« Reply #7 on: November 06, 2014, 04:22:00 PM »
Ok I have a small update for my car, I was incorrect and it does NOT have a M21 but infact is a M20, it has 2 rings on the input shaft
I dug this out of my storage area and it looks to be the matching transmission to the car VIN is 124378N378371 and the trans has stamping numbers 18N37837, also has P8A15 stamped on it
case has a 3925660 casted on the side, tailshaft has 3846429 casted on it, the side cover has a metal tag that I could not make exactly the numbers on it but looks to be 3915077
VINCE Z28
« Reply #8 on: November 06, 2014, 07:48:01 PM »
Extension housing ( tail shaft) for 1968 is # 3857584.  Colvin, page. 285 - 286.
Rsss396
« Reply #9 on: November 06, 2014, 07:56:03 PM »
colvin?
HawkX66
Dave
69 SS396 X66 L34 M21 BS
Z23 711 U17 Hugger Orange
Semper Fi!
« Reply #11 on: November 06, 2014, 09:20:35 PM »
The side cover has a metal tag that I could not make exactly the numbers on it but looks to be 3915077
3915077...
http://www.ebay.com/itm/ORIGINAL-69-1969-OLDSMOBILE-OLDS-442-MUNCIE-M-20-M20-4-SPEED-TAG-3915077-/161471406657?pt=Motors_Car_Truck_Parts_Accessories&hash=item2598722241&vxp=mtr
From eBay listing...
"Up for sale is an ORIGINAL 1969 Olds 442 Muncie 4 speed tag. This is GM part# 3915077 and is correct 1969 442's & Cutlass's with M-20 Muncie transmission. This is the tag came off of the side cover.  This is a hard one to find so do not miss out!!!"
There might be other applications too.  ???
1968 Z28
« Reply #12 on: November 06, 2014, 10:42:06 PM »
According to the '68 AIM, #3915077 is the transmission for L34, L35, & L48 engines.
Jerry G.
Z28-1968-07C-Norwood
2nd. Owner, 38,000 miles
Rsss396
« Reply #13 on: November 07, 2014, 01:54:37 PM »
the numbers game can be confusing haha, this chevelle site says 1964-70     http://chevellestuff.net/qd/muncie.htm
3846429
1964 - 1970 "Thin Fin Tail" Driver speedometer 27 spline
Rsss396
« Reply #14 on: November 07, 2014, 02:02:42 PM »
quote from a user on another site on the metal tag 3915077  http://www.yenko.net/ubbthreads/ubbthreads.php/topics/306322/2
That's a Muncie 4spd. wide ratio 2:52:1 as well.
Used originally in:
*1968 Passenger series w/8.15 X 15 tires w/3:55 axle AND when 396cid or 427cid. equipped.
*1968 Corvette w/o Posi or 3:55 axle.
And Recommended replacement in:
*1965-67 Passenger & Corvettes when NOT close ratio equipped.
*1965 Corvette w/o Spcl. Hi-Perf or Fi.
It was soon superceded in 1970 by Muncie #3964507 for same applications.
