Author Topic: Tic Toc Tach and MSD 6A ignition  (Read 7301 times)
chenoweth
« on: October 16, 2006, 05:21:14 PM »
I have installed a repro TIC TOC TACH in my 1968 350 coupe.  I have an MSD 6A ignition system.  I cannot get the tack to work.  We have tried every trick in the book.
Any advice?
supv26
  • 1969 Camaro
    • My 1969 Camaro
Re: Tic Toc Tach and MSD 6A ignition
« Reply #1 on: January 05, 2007, 12:22:43 AM »
I may be wrong but with the MSD6A you may need to install the in-line filter from the ignition. Not long ago I tried one of those replacement modules from MSD for my standard HEI and in the kit was a little wire that was supposed to be attached in between the tach and the distributor. Just a though and an idea.................
red69
« Reply #2 on: January 05, 2007, 04:13:55 PM »
I would call MSD. Their tech dept is very helpful. We installed a 6A on my son's 67 with a repo factory tach, hooked it up to the tach output on the box and it works fine.
Hope this helps Pat
