Author Topic: New guy, New project ' 67  (Read 85864 times)
Re: New guy, New project ' 67
« Reply #105 on: December 05, 2014, 02:51:40 PM »
At this point the only data I have collected show early LOS cars.  Still need more early NOR cars to add to my list to make a determination.  At least on the data I have been collecting.
MooneyDriver
« Reply #106 on: December 05, 2014, 03:47:58 PM »
if it helps any, here is the stampings on the rear quarters
What are you trying to determine?
'67  in progress
« Reply #107 on: December 05, 2014, 04:17:21 PM »
Decklid - they used that most of the way thru 67 production. There was an earlier version, but I'm not sure LOS ever got that version.
I'm also curious on the decklid date. Should have asked that. No hurry. :)
Thanks!
  The lid with the center elongated hole was for the '66 period, correct?
I'll correct my statement (I misread some data):
Yes, on 66 built cars, both NOR and LOS.  Changed on NOR cars about the beginning of the calendar year. Probably LOS too.
MooneyDriver
« Reply #108 on: February 08, 2015, 06:34:45 AM »
ok, been a few months since Ive had time to get any solid time on it, between the cold WX (no heat in the shop), and having to put a new motor in the inlaws exploder, I finally got to spend 5 hrs on it today, here what the damage I did.
Pass quarter is off, rear panel is off, piece between the trunk and window is off, fuel tank is out.
'67  in progress
MooneyDriver
« Reply #109 on: February 08, 2015, 06:35:30 AM »
so whats the trick to getting the piece of quarter out of here? Or should I have left a lip and butted it up? Might do that on the drivers side....  Thoughts?
ALOT of spot welds on this, I just went at it with a grinder on each weld, I counted like 86 just in that center section!
Had to put the new back piece on for fun! Its not a big deal, but gives ya the feeling of the new to come!
Under part doesnt touch it, I knew it was pushed in some, Ill bang on that once the quarter is sitting in place.
'67  in progress
« Reply #110 on: February 08, 2015, 06:42:24 PM »
Is that part of the build sheet on the right corner of the fuel tank?
MooneyDriver
« Reply #111 on: February 09, 2015, 12:36:28 AM »
I tried to read it but the lettering was gone, probably whatever they had at the factory for labeling parts?
'67  in progress
rick 67
« Reply #112 on: February 09, 2015, 12:41:53 AM »
 That is the factory build sheet do not disturb it. I am sure you will get lots of advice on how to safely remove  it. IT IS GOLD be careful !!!!!!!!!!!!!!
MyRed67
  • SZZLN 67
« Reply #113 on: February 09, 2015, 12:45:11 AM »
Mooney,  pic. #5 in that last group of pics., you need to read this; (Mystery part)
http://www.camaros.org/forum/index.php?topic=8653.0
that part is quite often left out when quarter panels are repaced.
1967 Camaro  LOS  11A
Original Engine   Z - Tribute
Mike C.    NW - Illinois
MooneyDriver
« Reply #114 on: February 09, 2015, 12:52:23 AM »
Oh? I thought the build sheets were on the interiors of the cars.
Yep, I know what it is, and to put it back on, it wasnt doing much, it has a HUGE gap to the quarter, and is welded to the 'gutter'
side view, and I didnt chip anything out, its just hanging in the breeze
'67  in progress
rick 67
« Reply #115 on: February 09, 2015, 03:13:03 AM »
 Ah the La built cars had one slapped on top of the gas tank.  Careful with it until some experts chime in about it.
Rick
MooneyDriver
« Reply #116 on: February 09, 2015, 03:24:52 AM »
Oh cool. Thanks Rick!
'67  in progress
« Reply #117 on: February 09, 2015, 04:01:20 AM »
It could be a piece of tape. Gotta clean it and see.
MyRed67
  • SZZLN 67
« Reply #118 on: February 09, 2015, 07:23:05 AM »
[/quote]
That article that posted link to states what you need to use to fill in the gap.
1967 Camaro  LOS  11A
MyRed67
  • SZZLN 67
« Reply #119 on: February 09, 2015, 07:24:43 AM »
Yep, I know what it is, and to put it back on, it wasn't doing much, it has a HUGE gap to the quarter, and is welded to the 'gutter'
That article that I posted link to states what you need to use to fill in the gap.
[/quote]
1967 Camaro  LOS  11A
