Author Topic: 68 RS Z28 - opinions please  (Read 17465 times)
bergy
« on: September 21, 2014, 12:38:19 AM »
I spent some time with the owner of this car at a show today.  He says that it's original engine.  I haven't studied a lot of SB stamps.  What do the experts think?  It's a cool car - RS, factory cowl plenum, 42k original miles, factory docs., original panels.
bergy
Re: 68 RS Z28 - opinions please
« Reply #1 on: September 21, 2014, 12:41:21 AM »
sorry that it's upside down.  Here's the car
bergy
« Reply #2 on: September 21, 2014, 12:43:27 AM »
this guy saved everything - smog, original air cleaner.  Says that cowl plenum came in the trunk when new?
jack92584
« Reply #3 on: September 21, 2014, 12:46:15 AM »
Really bad restamp
69 Z28 / Hugger Orange /  Deluxe Houndstooth  / M21 / 4:10 Posi / GM of Canada documented
« Reply #4 on: September 21, 2014, 12:48:28 AM »
Can you send me the original of the engine pad? I'll post an improved version of it....
« Reply #5 on: September 21, 2014, 01:20:47 AM »
PLenum and header were available in trunk when new... McNeish has a documented low mile one... pushed the Z28 option price to double the base.
Bergy,
Is it code E? Fathom? There was a Fathom blue 68 Z at MCACN last year that was awesome.
« Reply #6 on: September 21, 2014, 01:24:52 AM »
Bruce, was the guy's name Paul? The car was his son's correct? I looked at the car at the last show we were at together (you probably never saw it as he left on the early side) and the pad seemed correct to me both in broach marks and stamping but I'm no expert. The cowl plenum was the real deal but had a repro rubber sleeve. He gave me his name and address as I wanted to look the car over more closely. Nice to look for things on real Z/28's and of course, got to love those 68 Z/28's.... :)
dannystarr
« Reply #7 on: September 21, 2014, 02:11:49 AM »
Can't get the pic's much better. Never seen a baby "MO" stamp like that, and all crooked??? Guess I am about to learn something... Danny
jack92584
« Reply #8 on: September 21, 2014, 02:33:08 AM »
I may have been to quick to label it a restamp.I bet your right that were going to learn something here. Never seen a hand stamped MO before. Its so bad that I cant help but wonder if its some kind of factory correction, everything else on the pad looks good.
« Reply #9 on: September 21, 2014, 03:15:16 AM »
I need to clarify something here.... :) The stamping looked OK to me but not referring to the MO that apparently was hand stamped of course for some reason. Our MO was built 10 days after this one and much of the assembly build date stamp looks the same. It for sure is interesting as I never saw a MO like that but again the rest seemed to fit the bill. I took a picture of it with my cell phone but not much better than what Bruce showed.
« Reply #10 on: September 21, 2014, 04:31:04 AM »
Someone mounted the alternator like a Pontiac.  :P
1968 Z28
« Reply #11 on: September 21, 2014, 04:14:39 PM »
Alternator is mounted in the smog pump mounting bracket.  ???
Jerry G.
Z28-1968-07C-Norwood
2nd. Owner, 38,000 miles
« Reply #12 on: September 21, 2014, 06:49:32 PM »
Little backyard innovation. I do not know how sturdy the mount was on the Kustom headers ,but personally I hate the after market brackets, (pre 69 set up) always an issue with bending, cracking and header leaks.  Looks..??.., but a functional solution was found utilizing what they had. Credit due.
Interested on hearing a little more about the car.
Can't make out driver's , wrong passenger head ,accessory holes. Late in the year?
« Reply #13 on: September 21, 2014, 07:08:31 PM »
Low mileage '68 Z? Sounds like everyone's got one.  ;)
« Reply #14 on: September 21, 2014, 07:44:30 PM »
CORRECTION:  Low mileage '68 Z? Everyone wants one!  :)
