Author Topic: 302 Block ?  (Read 27749 times)
Alan
Re: 302 Block ?
« Reply #15 on: November 29, 2005, 11:05:58 PM »
From what I can read the axle code is BG0219G2 with an E under it. Casting date, I think, is B79. I will  get you a picture of the tag in the next couple of days. The VIN by the Oil Filter is not legible. Trans reads PNM22.
Re: 302 Block ?
« Reply #16 on: November 30, 2005, 05:59:48 AM »
BG isn't a good 69 axle code. BS? But that axle isn't original to either the tag or the VIN. Is it a 10 or 12 bolt?
The picture of the pad will help. And the VIN by the oil filter is the key evidence that's missing. It is hard to see in the car.....
The N in the trans code should be a number. No VIN stamped near that code?
McKenzieDave
Re: 302 Block ?
« Reply #17 on: January 12, 2006, 07:51:08 PM »
LET'S START FROM THE BEGINNING.  YOU HAVE A COWL TAG DESIGNATING 1ST WEEK OF DECEMBER BUILD (12A) AND A NORWOOD SEQUENCE OF 130231.  YOUR VIN IS 9N685148.  1969 WAS A LONG PRODUCTION YEAR WITH BUILDS IN DEC. 68 AND DEC 69.  YOUR VIN SEQUENCE IS CAR NUMBER 185148 (STARTS AT 500000 FOR 1969.  THIS JIVES WITH THE DECEMBER 69 BUILD (CHECK OUT PRODUCTION TOTALS IN YOUR RESEARCH).  YOU SAY YOU CAN SEE A PRTIAL VIN DOWN LOW WITH N685???.  IF YOU LOOK AT YOUR VIN THESE NUMBERS ARE PRESENT, THIS COULD BE REAL IF YOUR OBSERVATIONS ARE TRUE AND CORRECT.  THE ONLY ODDITY I FIND IMMEDIATELY IS THE ENGINE WAS BUILT IN SEPT AND CAR BUILT IN DEC.  THIS IS QUITE A SPREAD IN DATES, BUT NOT IMPOSSIBLE.  DON'T FORGET, A LOT OF THESE ENGINES WERE BUILT AND 1970 INTRODUCTION WAS POSTPONED FOR A WHILE.  ENGINES BUILT FAR AHEAD OF SLATED Z-28 ORDERS COULD BE VERY POSSIBLE IN THIS CONFUSING NIGHTMARE OF GM DEVELOPMENT.  DON'T MISS THAT THESE CARS WERE BUILT IN NORWOOD AND LA (VAN NUYS).  THE NOR SEQUENCE OF 130231 ALSO JIVES.  LASTLY, THE REAREND IS NOT A BIG DEAL, LOTS OF THEM BROKE.  NO AXLE HAD VIN NOTATION ANYWAY.  HOPE THIS HELPS, ALL OF THESE ANSWERS CAN BE FOUND WITHIN THIS SITE WITH A LITTLE PATIENCE.  DAVE
Re: 302 Block ?
« Reply #18 on: January 13, 2006, 03:56:16 PM »
Nope - the last '69 build week was 11A (November), and his 12A tag doesn't belong on that car - it's been swapped from a December '68-built car.
Please turn off your Caps Lock key - makes your post hard to read, and caps are considered as "shouting".
