Author Topic: 67 vent window rubber, clips ?  (Read 4572 times)
paulmanta
« on: August 13, 2014, 06:54:12 PM »
I have just got my new vent window rubbers for my 67 and I noticed when the old ones were removed the remains of three little clips.
Both sides are stripped, I managed to save two clips, the others were just rust.
Question shall I bother to find a set to put the rubber back in or should I just use the two I do have and forget the rest.
None of the vendors I normally use have these little things in stock so I am not sure where I would get more. possibly a breakers or from another forum member if they had some spares.
paulmanta
Re: 67 vent window rubber, clips ?
« Reply #1 on: August 14, 2014, 05:14:44 PM »
These little fellows !
4 per side it seems,
big iron
« Reply #2 on: October 19, 2014, 03:35:40 AM »
There must have been a reason why GM installed them.
Anybody???
Bob
paulmanta
« Reply #3 on: October 19, 2014, 07:36:38 PM »
As the OP of this topic I will reply and just update.
I fitted the rubbers using just one clip per side, sort of between the hinge for the vent window and the top.  Its all fine and the rubber stays in place.  Not going to bother tracking down more if its ok with out them !
