Author Topic: 69 Z/28 X77 garage/barn find  (Read 278477 times)
69 Zee
Re: 69 Z/28 X77 garage/barn find
« Reply #150 on: August 29, 2014, 02:54:12 AM »
Could this PVC and hose with the 2 black pinch clamps be the originals ?  I understand that the PVC could of always been changed for a replacement but what about the hose ?  There's 3 ridge like lines down the hose with no other markings.  Was this a common GM type hose or did they usually have a p/n printed on them ?
Darrell
'69 Camaro Z/28: 03B NOR X77 Dusk Blue, white top, all orig, Under construction
'70 Plymouth Superbird: One owner, Limelight green, 45K miles, all original U code
« Reply #151 on: August 29, 2014, 02:58:59 AM »
based on the other survivor thread, I would say that is the original, with the original clamps. Great find, I think I may need one!
69 Zee
« Reply #152 on: August 29, 2014, 03:06:21 AM »
Hmmm.. I guess I better hide it...lol
Darrell
69 Zee
« Reply #153 on: August 29, 2014, 03:14:13 AM »
Original Winters Intake and Carb.  A tad dirty I'd say   ;D   Anyone have an idea to why there's a "Q" stamped on the Intake (last pic) ?  I've seen other Intakes without.
Darrell
« Reply #154 on: August 29, 2014, 03:18:57 AM »
interesting different water neck, ( no provision for return spring). Wonder why they swapped that off.
69 Zee
« Reply #155 on: August 29, 2014, 03:20:59 AM »
Yeah I have the original water neck coming up !  :)  That's an old chrome one
Darrell
« Reply #156 on: August 29, 2014, 03:23:42 AM »
Chrome water neck of corse the easy way to customize the engine compartment back then....
« Reply #157 on: August 29, 2014, 03:33:05 AM »
Inspection stamp...  http://www.camaros.org/forum/index.php?topic=8598.0
69 Zee
« Reply #158 on: August 29, 2014, 03:36:39 AM »
Chrome water neck of course the easy way to customize the engine compartment back then....
LMAO... heck yeah !!
Darrell
69 Zee
« Reply #159 on: August 29, 2014, 03:39:22 AM »
Here we go, the #3877660 Alum housing... let's pitch that chrome one !
Darrell
69 Zee
« Reply #160 on: August 29, 2014, 03:51:48 AM »
That's interesting.  So would it be safe to say that not all Intakes received this "inspection" stamp since I've seen some without ? And if that's the case then were they stamped periodically just for quality control every so often ?
Darrell
« Reply #161 on: August 29, 2014, 01:28:20 PM »
Looks like you got a real keeper there, nice original stuff Darrell.
Dusk Blue Z
« Reply #162 on: August 29, 2014, 02:02:58 PM »
Hey Darrell,
Thank you for posting all the detail pictures of your Z/28. Could I request some more?
I am pretty sure your PCV, hose, and clamps are original. I would like to see the PCV valve to see what if any markings are on it. Also the choke vacuum pull off front and back, and the heads of the coil mounting and distributor clamp bolts.
I am kind of partial to the paint code too.
1969 Z/28 Legends Certified
1969 Z-10 350 4 speed
69 Zee
« Reply #163 on: August 29, 2014, 02:21:20 PM »
Hey Darrell,
Hey Mike, by your username I'm guessing you are playing a favorite  ;)   May I ask, do you have a Dusk Z ?   and yeah n.p. on the request.  I'm currently at work today (work 24 hrs as a Firefighter) and won't be home until tomorrow morning.  Funny you should ask because after I posted the intake pics I noticed the bolts and also thought of checking the heads out.  Check back tomorrow and I'll see if I can't have all yours answers with pics.
Darrell
69 Zee
« Reply #164 on: August 29, 2014, 02:27:38 PM »
Thanks Bentley,  yeah I'm very happy.  Other than the 2 components I had mentioned earlier,  I think I just about hit every nail on the head.
Darrell
