Author Topic: 69 Z/28 X77 garage/barn find  (Read 316519 times)
69 Zee
Re: 69 Z/28 X77 garage/barn find
« Reply #345 on: December 02, 2014, 12:43:06 AM »
In reference to #177 post by Gary.  Here's the double male Oil Fitting for all console w/gauges.  I believe I have the top female half in another box,, I remember seeing it among the first wave of nuts and bolts I rifled thru  ;D
Darrell
69 Zee
« Reply #346 on: December 02, 2014, 12:45:14 AM »
I like the goodie boxes, exciting to say the least.
I really like the color on that olds. It seems to be a great color for the big A bodies, a 70 Chevelle in that color is a favorite of mine.
Austin, On the goodies,  to funny but your right.
Darrell
69 Zee
« Reply #347 on: December 03, 2014, 06:10:53 PM »
Original Smog Pump Diverter Valve p/n 29295 and the LH Smog Tube w/check valve (RH side was on post #137)
Darrell
69 Zee
« Reply #348 on: December 03, 2014, 06:44:44 PM »
Not sure if original but they are GM hoses on the Smog Pump Diverter Valve.  One GM hose looks like p/n's 3932476 (unsure if last no. is a 6) and other 3932478 with and hose clamps.
Darrell
« Reply #349 on: December 03, 2014, 06:48:24 PM »
Those tower clamps (being as old/rusty as they are), are almost guaranteed to be original.   Clean them thoroughly, then soak them in Evapo-rust or Metal Rescue until the rust is removed and maybe they will be usable.. :)
« Reply #350 on: December 03, 2014, 07:27:13 PM »
No wire reinforcement on the muffler. Often seen on others.
262jp
« Reply #351 on: December 03, 2014, 10:00:39 PM »
Could you post a pic of the overall length of the double male oil line fitting. That piece is missing on my 69 Z and I am making up a few. I think the first one I have made might be a shade too long overall. Just trying to get it right. Thanks
Stingr69
« Reply #352 on: December 04, 2014, 01:23:17 PM »
FYI - I have "29295" without the wire reinforcement. I have seen them both ways
-Mark.
69 Zee
« Reply #353 on: December 05, 2014, 01:45:11 AM »
The actual overall length is exactly 1-1/2 long
Darrell
69 Zee
« Reply #354 on: December 05, 2014, 02:44:30 AM »
-Mark.
I looked over the muffler and diverter valve very well today.  I saw no evidence anywhere that there may have once been a reinforcement wire ("V" shaped) attached to the front.   So that sent me searching.   I've noticed many without, actually more without than with.  CRG 1967-69 Camaro Emission Systems there's a pic of the '69 diverter and muffler p/n 29295 and it's without.
http://www.camaros.org/emissions.shtml#valves
Now with that being ... question?  Was there 2 different ones used at any given time ?  Was there a possibility of an early production version and a late version,  Mine being mid 03B without ? Or all those without, were they just simply broken "CLEAN" off for no rhyme or reason ?  .... just curious now.
« Last Edit: December 05, 2014, 03:38:03 AM by 69 Zee »
Darrell
69 Zee
« Reply #355 on: December 05, 2014, 03:36:18 AM »
Reference to my 03B build and the post just before.   Pic 1)  Is the face of my original diverter and muffler.  It does not appear to have ever had the "V" shape reinforcement wire attached.   Pic 2)  Is one I happened to find with the reinforcement wire
Thought it was interesting enough to post after Kurt had mentioned that most had them.  Any thoughts as to why some have and some don't ?
Darrell
« Reply #356 on: December 05, 2014, 04:02:52 PM »
Actually, I said "Often seen on others." I think most did not have the wire. But it's not uncommon.
I've never studied it enough to find a pattern. I've seen it on NOS parts and original parts. Never seen one on 1970+ cars that I can recall.
69 Zee
« Reply #357 on: January 12, 2015, 06:19:15 PM »
Original deep groove Smog pump pulley #458DA
Darrell
69 Zee
« Reply #358 on: January 12, 2015, 06:24:08 PM »
These are the wiper arms I received also.  Anyone know if these would be the correct Trico part numbers thus possibly being the originals as well ?
Darrell
« Reply #359 on: January 12, 2015, 08:06:46 PM »
They appear correct to me....  :)
