Author Topic: 69 Z/28 X77 garage/barn find  (Read 333504 times)
ban617
Re: 69 Z/28 X77 garage/barn find
« Reply #225 on: September 12, 2014, 02:29:16 AM »
 Darrell ,Get all your stuff cataloged then come & do mine ....
69 Zee
« Reply #226 on: September 12, 2014, 02:36:12 AM »
 Do you have the nut for the junction block ?
Hey Rob,  Yeah Right...lol
Yes I have it.  It's a washer fixed to a nut.  I had removed it to make sure it wasn't rusted on.  I noticed after I posted my pics that I wasn't showing the nut/washer... ugh !  I'll have to slip another updated pic in here.
Darrell
« Reply #227 on: September 12, 2014, 03:22:49 AM »
Regulator very probably will work fine. They last.
« Reply #228 on: September 12, 2014, 04:06:53 AM »
The regulator is a mechanical unit; it has points that can be cleaned which usually lets it work again ....
69 Zee
« Reply #229 on: September 12, 2014, 01:06:55 PM »
Thanks guys in reference to the Volt Reg.  That's good to know.
Here's the original Control Arm Lower Bumpers p/n 3928362.  The LH (drivers) side part no. was turned in toward the coil spring.  Making it hard to get the number since I haven't disassembled yet.  But you can make out the last few numbers and letters   ;D
Darrell
« Reply #230 on: September 12, 2014, 01:43:03 PM »
Your lwr control arm bumper seems to be original (although very deteriorated) ..  same PN as mine...  the '46' in your case, '1' in mine...  would seem to be some type of date coding...?   below photo is my original..  PN 3928362 FK
69 Zee
« Reply #231 on: September 12, 2014, 01:55:12 PM »
Gary both of mine show the "FK",  my RH shows the numbers 46 after and the LH appears to be "55" as you have a "1".  Not sure why they differ or how, but leads me to believe there may be other numbers as well.
Darrell
« Reply #232 on: September 12, 2014, 01:59:58 PM »
typically those kind of numbers are a date code..might be week of the year (although the 55 example says NO to that), most probably is the Julian date...  or possibly a mold number?
The PN is the 7 digit code..  FK might indicate the manufacturer, and the following number the date code or mold number.
69 Zee
« Reply #233 on: September 12, 2014, 07:29:13 PM »
If they're Julian dated then I'd be happy with that.  The 46 would be Feb 15 (Sat) and 55 would be Feb 24 (Mon)  I could live with that.  :)
Darrell
69 Zee
« Reply #234 on: September 12, 2014, 07:33:31 PM »
Ref. to my 03B build.  The dated Voltage Reg is "9C"  (March)  and is hidden under the capacitor bracket.
Darrell
« Reply #235 on: September 12, 2014, 10:51:01 PM »
[/quote
The dates might be good, but IMO, your bumpers need replacing...  :)  PS.   I've been told when you need to do necessary safety related updated to your car, put the original parts in a bag and keep them.... :)
69 Zee
« Reply #236 on: September 13, 2014, 03:45:22 AM »
[/quote
That's my full intentions.  Any part that can't be saved or used for safety purposes will be bagged, tagged and stored away.  It would be nice if I'm able to find an original set of those bumpers.  I'll most definitely be searching
Darrell
« Reply #237 on: September 13, 2014, 06:23:58 PM »
Those are cavity numbers in case there is a problem the particular offending mold cavity can be isolated.
69 Zee
« Reply #238 on: September 13, 2014, 08:30:09 PM »
Thanks James.  Good to know ...so any numbers after the p/n will be correct to use.
Darrell
69 Zee
« Reply #239 on: September 13, 2014, 08:49:54 PM »
Nothing of great deal,  just the correct factory Fan Shroud Bracket and the mounting hardware.  I did not notice any markings on the heads other than 3 hash marks.  They also appear to be the same size as the mounting bolts that affix the top/inside of the fender to the top of the Radiator core support.
Darrell
