Author Topic: Final adjustment on RS Headlight doors  (Read 21552 times)
Charley
Re: Final adjustment on RS Headlight doors
« Reply #15 on: August 08, 2014, 05:16:26 AM »
Or you could do what I said earlier and tweek the bracket in the same direction that would make it just like shortening the actuator shaft.
Steve Shauger
    • Vintage Certification
« Reply #16 on: August 08, 2014, 04:12:53 PM »
As Charley suggested, in the past I've tweeked the bracket to get the door to close the last 1/4 inch.
Steve Shauger
rszmjt
« Reply #17 on: August 09, 2014, 06:04:04 AM »
Try switching the actuators side to side and see what happens. Also you might see if the inner door is rite up against the bumper, I had a Z28 a while ago I had to trim down the bumper.
sixt9x33rs
« Reply #18 on: August 10, 2014, 02:10:40 PM »
Before I took the car apart to paint it both doors shut perfectly. I hate to tweak an original part to make the door fit....at this point anyway. But may end up doing just that.
« Reply #19 on: August 10, 2014, 05:15:21 PM »
have you tried loosening all the relevant fasteners.. making sure it opens/closes easily, then carefully snugging them back ??
Charley
« Reply #20 on: August 10, 2014, 06:44:52 PM »
You won't even notice you tweeked it.
sixt9x33rs
« Reply #21 on: August 11, 2014, 11:37:18 PM »
The part to tweak is the cross bar that the rear of actuator attaches to, right?
jmcbeth
  • 1st and 5th Gen Camaros
« Reply #22 on: July 03, 2017, 10:36:11 AM »
Did you ever figure out the problem? I am experiencing a similar problem. The actuator bottoms out before the door hits the rubber stop, leaving a gap on the outer edge of the opening in the grille. Any advice would be appreciated.
John
1969 Camaro Z/28 RS
Numbers Matching
sixt9x33rs
« Reply #23 on: July 23, 2017, 12:18:07 PM »
No I have not figured it out. I did "tweak" the bar Charley was referring to and did not seem like it helped. Maybe I was tweaking the wrong part. I don't have the car home at the moment. It is at the shop and I have been working on other cars. Let me know if you fix your problem John.
Lawrence
