Author Topic: Decoding a Pace  (Read 14852 times)
jjonesls1
Decoding a Pace
« on: July 24, 2014, 08:27:39 PM »
Hello,
I could use some help in trying to determine what I have here. I've done a fair bit of reading, and believe I have decoded the VIN and cowl tag correctly using the resources found here. I'm really hoping to be able to find out more about this car if possible. I have yet to find a resource that would allow me to recover a factory window sticker or build sheet, and have had no luck locating the build sheet in the car. Any insight you could shed, or other resources you could suggest would be much appreciated! I'm really hoping to track down the equipment list for the car, and most importantly verify that it was originally and A/C car. It appears to be in every way, but sometimes you just want to see it in writing, ya know?
VIN - 124679n619605
Cowl Tag info-
ST69 12467
TR720
03D
NOR285367 BDY
50A PNT
Z11
Thanks!
Re: Decoding a Pace
« Reply #1 on: July 24, 2014, 08:40:05 PM »
First things first.  Welcome.  Best thing to do is post a pic of the trim tag & vin as well as the hidden vins..  As far as what you have posted the numbers look ok but cant say 100% without see the items I have listed..
« Last Edit: July 24, 2014, 09:52:04 PM by cook_dw »
6667ss138
Re: Decoding a Pace
« Reply #2 on: July 24, 2014, 08:51:56 PM »
There are some pace car experts on here so you came to the right place. I'm sure they will chime in and help you. They will want pictures of the Cowl tag and anything else that you can show like engine pad stamp, trans and rear end numbers. The information you have listed points to a true Z/11 pace car but again without pictures they are only numbers. Also, I'm pretty sure you won't find a build sheet on a Norwood built car and without some of the original factory docs such as Protecto Plate, original owners info etc I don't think you will be able to find the information you are seeking. There is no original GM source out there to retrieve factory docs like the GTO's for example. You can find out the original GM shipper and build date info from the NCRS. Check out the link below. I used to own a Z/11. They are one of my favorites. And as Darrell says, Welcome!
http://www.camaros.org/forum/index.php?topic=11724.0
jjonesls1
Re: Decoding a Pace
« Reply #3 on: July 24, 2014, 09:08:51 PM »
Thanks for all of the help so far! I've got pictures of the vin and trim tags, but not the other locations. I don't have access to the hiddne vin locations at the moment, so hopefully that is enough to get us started.
I'm struggling with attachment sizes, giving it another shot
Re: Decoding a Pace
« Reply #4 on: July 24, 2014, 09:18:09 PM »
It should look like this - 600+ cars ahead of mine, 973 from the body tag. My car was built 3/26, shipped to Texas. 350/350, PS,PT,PDB,A/C car. Probably same day, or a day off. Not bad -
Close enough ? I thought so -
Use Light Image Resizer software, free download. Save it as a jpeg, downsize to 800X600, or 600X480, and you can transfer them all day.
Re: Decoding a Pace
« Reply #5 on: July 24, 2014, 09:35:49 PM »
BTW, the tag looks O.K, with the exception of the masked paint line on the cowl ledge. I assume the car has been painted, at least in the firewall/underhood area. A/C box intact, or removed ?
VIN looks unmolested, plus all the numbers line up with mine. The only other things you can't know for sure are the options, but at least the production timing of the car, TT, and VIN line up fairly well. The chances of someone finding a close TT and installing on this close VIN'd car are pretty remote IMO.
Regards -
jjonesls1
Re: Decoding a Pace
« Reply #6 on: July 24, 2014, 09:47:03 PM »
Thanks! A/C box is intact. Is there no way to find the original build info it it's not with the car? I'd just have to get lucky and find it on the car?
69pace
    • TeamCamaro - Moderator
Re: Decoding a Pace
« Reply #7 on: July 24, 2014, 11:41:27 PM »
At this point in time the Chevrolet build records are presumed destroyed so unless your vehicle was exported to Canada there are no official records besides the rare dealership cache and of course the original owners copies. SO if you are lucky to have the POP and dealer invoice your all set.
My Z11 is two weeks earlier 03B And your vin sequence is in line for the production date. Body numbers can be misleading since the number is generated by the central office based on order, and may take weeks for the body number to be released based on options and availability.
What shape is she in? Have you posted over at Team Camaro?
Re: Decoding a Pace
« Reply #8 on: July 25, 2014, 12:16:22 AM »
One shot you might try. Depending on your state, your DMV might have saved copies of your dealer invoice, title copies and even the MSO if your car was sold new in your state. I was fortunate to have both my '69 Z and '68 Z's complete history, including dealer invoices and MSO's copied by the state, and microfiched. Cost to copy and give to me - $5.00 for the '69, $15.00 for the '68 (years later). The bad side - TN stopped doing this several years back due to "lack of funding for personnel overtime". Stinks.
You can always try it - might get lucky. If you do, backtrack the previous owners and/or dealerships involved. You never know - takes a lot of work, but it could really pay off in the long run -
Regards, and good luck. Keep us informed -
jjonesls1
Re: Decoding a Pace
« Reply #9 on: July 25, 2014, 04:56:33 PM »
Thanks for the help guys! Another question for you. I have looked high and low for this information, but been unable to find it -
I'm curious to find a breakdown of production numbers on the '69 Pace cars. Is there a way to find out how many of the '69 pace car convertibles were built with A/C? This is a 350 A/C car. I am comparing this to another pacer that is a 396 car w/ no A/C. Is there a way to find out the production #'s for each, and which would be more rare?
Re: Decoding a Pace
« Reply #10 on: July 25, 2014, 06:26:37 PM »
Good question. I'll take my shot; then others can shoot at me -
Out of all the 1969 production Camaros, roughly 18% were equipped with C60 air conditioning. You can bet the percentage of convertibles w/ A/C was a lot lower, maybe 10% ? Less ? Good time for the numbers gurus in residence -
6.5% of total production (15,866) were V-8 convertibles. Of that number, 23% (3675) were Pace Cars. If you assume (I don't like the word, but there it is) 10% of Pacers were A/C cars, you would get about 367 total. How many big blocks ? roughly 200-300 from what I have read - if you apply the same formula to big 'uns as little 'uns, you'd get about 20-30. Rule out the 375 horse cars from the mix, cause solid lifter cars could not be A/C equipped by rule. My estimation - a lot lower number than that on both sides of displacement combinations. Probably saw very few in the northern climes, more in the south and southwest (which is one of the reasons I believe my Z11 was fortunate). I have seen a couple that had dealer-added underdash air, but it's uncertain at what point people added them. On a local level, of the three Pacers that were owned in this area, two had A/C, one did not. All three are small blocks.
This is conjecture on my part. I would have rather you asked how many had the ZL2 hood (lol) - we know that percentage !
Other opinions ?
Regards -
Re: Decoding a Pace
« Reply #11 on: July 25, 2014, 06:31:42 PM »
I believe I knew 2 of those local cars personally..   ;) ;D
6667ss138
Re: Decoding a Pace
« Reply #12 on: July 25, 2014, 07:14:13 PM »
I'm not sure about rarity but in my "opinion" a real numbers matching big block pace car will bring more money than a real numbers matching small block pace with A/C. That is if we are talking same basic condition and documentation, trans etc
Now others can shoot me :)
jjonesls1
Re: Decoding a Pace
« Reply #13 on: July 25, 2014, 11:35:38 PM »
I think I would be inclined to agree with you to an extent. The trouble I'm having is deciding how much more. $10k?
6667ss138
Re: Decoding a Pace
« Reply #14 on: July 26, 2014, 12:49:50 AM »
Yes, again just my opinion and I'm not really in the loop with the latest price guides and auction results for pace cars but I believe a real, original docs, numbers matching big block, non A/C, Z/11 (especially a 4 spd car) is worth 10K more than an equivalent small block pace with A/C. I think that is a fair number.
Without giving away the location of the cars you are looking at do you have any more info or photos that you can share as far as condition and options
to compare with?
Here are a couple Hagerty price guide reports.
http://www.hagerty.com/valuationtools/HVT/VehicleSearch/Report?vc=1100569
http://www.hagerty.com/valuationtools/HVT/VehicleSearch/Report?vc=501529
