Reassembly Prep... Got every surface wiped down one more time with Lacquer thinner. Applied small beads of Permatex around water holes, set gaskets, applied a bead around water jackets on top of gaskets. Ran 3/8ths high bead at the front and back. And a small mound at all 4 corners. Applied some to each bolt threads and installed. Started by running all of them in until they touches. Then pulled my alignment pins. Word of advice, do not make them out of stainless. Would have been nice to get them with the telescopic magnet. Wrong stainless, non magnetic. Started in the center and worked my way out at 15 #'s, then 20, then 25. Bouncing back and forth, middle to back, then middle to front. Until all were at about 27 #'s.... Danny
