Author Topic: My New '68 Camaro Z/28 Butternut Yellow  (Read 441274 times)
dannystarr
Re: My New '68 Camaro Z/28 Butternut Yellow
« Reply #645 on: December 23, 2014, 09:44:45 AM »
Picked up some more parts. Got an original late '68 build solid rivet Rad Cap, Repro Battery Cables, Spark Arrestor, Wiper Arms, Blade Holders, ... Repro Packard Plug Wires, Heater Hose, White Striped Vacuum Hose... Danny
dannystarr
« Reply #646 on: December 23, 2014, 09:46:38 AM »
Wires
dannystarr
« Reply #647 on: December 23, 2014, 09:47:19 AM »
Arrestor
« Reply #648 on: December 23, 2014, 06:29:21 PM »
Danny, can you post a picture of what you picked up in wiper arms and blades?
I got mine since we last talked..... You won't believe where I got mine. :)
dannystarr
« Reply #649 on: December 23, 2014, 07:50:22 PM »
Didn't get the blades yet, but blade holders. And also the arms. Turns out, if these are correct arms... they match the ones I already have. Pictures later. Gotta go finish X-Mas shopping.. And then take the car for a spin!! ... Chick, I just sent you an email with some picture on another subject... D
« Reply #650 on: December 24, 2014, 02:54:31 AM »
Radiator cap looks like it was left outside right next to your car, a spot on match.
Those plug wires look to good, your going to have to drag them around the block a few times .. :D
dannystarr
« Reply #651 on: January 14, 2015, 03:06:32 AM »
Here is the Solenoid bracket installed. Put it right where it looks like it once was. I can see the change in the dirt and rust line  ;D..
dannystarr
« Reply #652 on: January 14, 2015, 03:08:16 AM »
more
dannystarr
« Reply #653 on: January 14, 2015, 03:08:37 AM »
more
dannystarr
« Reply #654 on: January 14, 2015, 03:09:06 AM »
more
« Reply #655 on: January 14, 2015, 03:56:53 AM »
so what is the purpose of that second circular 'loop' in the bracket??
« Reply #656 on: January 14, 2015, 04:10:33 AM »
Probably to rest against the starter housing and keep the bracket from being able to rotate, which would pull on the wiring.
dannystarr
« Reply #657 on: January 14, 2015, 07:05:53 AM »
I was wondering that myself. Makes sense to me...  :D :D ... D
dannystarr
« Reply #658 on: January 15, 2015, 11:26:03 PM »
Well I got my hot side battery cable mounted. Put that all back together last night. Note the battery hold down with the "K" stamp. The ground cable bolt and washer for the firewall. Soaked all in evaporust over night. That washer sure is special. Would hate to try to find one.... Danny
dannystarr
« Reply #659 on: January 15, 2015, 11:27:08 PM »
washer again and bolt with embossed "D"... D
