WELL... I think I am going to buy a dial indicator. Be nice to have, and seems the correct way. In high school I stuck a stick down there and slowly turned the crank until I though it pushed out the farthest. TOO funny!
Then I will take my dremel tool and make a baby line nice and clean and straight.
I like the idea of the tape so I can mark it all the way around in several places. But what is the best advance for regular street driving. 32, 35, 36, 38??? I keep getting different numbers suggested.
So ok, I will have the distributor re-curved. He has done 302 units before. Did my friends 302 unit and he says it runs great. And to save all old parts.
Having the alternator rebuilt at the same place. Internally only. So as to keep the survivor visual.
Appreciate it guys. Will update soon hopefully... Danny
Kelly King is correct (actually nobody who posted is wrong !) Once the piston is up....use your stick (a pencil is cleaner LOL) and rotate the crank CW/CCW just a little and leave it at the highest. Rockers should be loose. Dial indicator... well I just love tools so no foul there.
Somebody else brought up about your balancer being off (inertia ring may be going ) Correct, have it checked out at the speed shop. I had one go bad on a 400,and one higher dollar after market show out of spec on the dyno. happens.
Reference marks are great to go by if it was never pulled ,or you marked it. Shaft may now be off in relation to the body. None the less great advise. Because...
1. your at TDC (pencil at it's highest !)
2. rotor points to #1 cylinder and #1 post on the cap
3. Alignment marks check out. Properly reinstalled. period.
Total advance? what are you guys in Cali running?? From the mild 302 to the wild 413 (throw in a few 327's) they all seemed to like 38 degrees total--with good fuel.
Better than the tape ,is an adjustable timing light, however ,little nostalgic and does serve a good purpose...for cheap.
Still say it's a shame we can't all pick up a 12 pack,head over there and get this old Z fired up !---steve, I even got a set of old big tube SuperComps that sound oh so sweet uncorked on that 302.
