Author Topic: Cowl Tag Codes Sep 68 vs Sep 69  (Read 8708 times)
mgw76
« on: July 08, 2014, 04:42:51 PM »
I'm looking at a car that is supposed to be a '69  RS/Z-28 and the owner supplied a photo of the cowl tag.  Paint color and interior line up with the tag but no X33/X77 code.
From what I've found on this site, if the car was produced prior to mid-December '68 there isn't an X code on the Norwood built Camaros.  According to the date code on the cowl tag the car is supposed to be a September, 3rd week build.  Since the '69 was a long model year run (July '68 to Nov '69) is there any difference in the date code for a car built in Sep '68 and a car built in Sep '69?
Re: Cowl Tag Codes Sep 68 vs Sep 69
« Reply #1 on: July 08, 2014, 05:14:38 PM »
No. In your example, 3rd week of September (09C), it would be the same on a 1968 tag and 69,70 etc....So, a Sept.68 and Sept.69 would both show 09C on the TT. Also, remember, the tag size changed between those two example dates. Make sure the VIN corresponds with the time frame of the TT.
rick 67
« Reply #2 on: July 08, 2014, 06:49:41 PM »
X codes did not show up until Dec? 1968 for the 69 model year. My former 69 rs/ss vert had no X code but with a n509386 vin it was a sept 68 build PRE X code. Sept 69 builds would have a vin in the high 600,000 range or low 700,000 range I believe without looking it up.
Rick
Kelley W King
« Reply #3 on: July 08, 2014, 07:18:29 PM »
x codes appeared around 12B of 68. My 12A 55xxxx has no X code.
69 SS L78
67 SS Chevelle
64 Corvette
66 GTO Tiger Gold
77 Trans Am Special Edition
mgw76
« Reply #4 on: July 08, 2014, 07:50:02 PM »
Thanks!
I'll keep this in mind when I get to see the car.
westonz28
« Reply #5 on: July 10, 2014, 05:56:22 PM »
You can check behind the rear seat for markings, ie x7,x4,x1,3 they will be in yellow crayon. good luck.
67 RS L30/M20 numbers, 68 BB 396 12 bolt posi
68 Z28 project, 68 numbers 327/210 4 speed
69 LM1 turbo 350 12 bolt numbers,70 L65 350
68 Chevelle L30 3 on the tree, 68 El Camino BB
Mark
« Reply #6 on: July 10, 2014, 09:06:52 PM »
They will be in yellow paint pen or grease pen UNDER the glue used to attach the package tray vinyl to the metal structure of the seat support.  Very important that they be under the glue, because I have seen people add them to cars but the markings were on top of the glue residue.  People will do anything for a buck these days.
Mark C.
1969 Indy Pace Car
350/300HP RPO Z11
« Reply #7 on: July 10, 2014, 10:27:17 PM »
Funny, the question was about Trim Tag date code-NOT X codes or markings on seat backs!
VINCE Z28
« Reply #8 on: July 10, 2014, 10:58:03 PM »
X2 James  ;)
rick 67
« Reply #9 on: July 10, 2014, 11:57:44 PM »
 Hmmm and for a rookie  I thought I explained it pretty good ? Back to the drawing board darn.
« Reply #10 on: July 12, 2014, 01:51:19 PM »
You did good..  even told him how to check bdy nbr to verify which year...  :)
TooManyReels
« Reply #11 on: July 12, 2014, 10:55:03 PM »
I'm no expert by any means, but a few other things to also look for in helping to determine if it's a true RS would be the stainless trim on the front parking lights and the back up lights were in the lower valance panel and not the tails lights.  Unless, someone went through a lot to make into a RS by changing these out.
TMR
Eddie
Eddie
63 Chevy II SS 570hp 560tq.
69 Z28 X33 Cross Ram JL8
