Author Topic: HURST COMP. PLUS SHIFTER LOOSE LINKAGE FOR M-21  (Read 6161 times)
VINCE Z28
« on: July 07, 2014, 06:57:30 PM »
Does anyone known were I can get  shifter shaft adapter clips for a non stud trans where the linkage bolts up to the side cover for Hurst comp. plus linkage.
Re: HURST COMP. PLUS SHIFTER LOOSE LINKAGE FOR M-21
« Reply #1 on: July 08, 2014, 11:09:43 PM »
Baxter is the onlu place I've ever found parts like that unless you look on-line.  I'm not sure if they have them, but I bet they could get them.  There's one in Jantzen Beach
« Reply #2 on: July 08, 2014, 11:50:35 PM »
Unsure of your description - are you looking for the spring clips/bushings http://www.summitracing.com/parts/huu-3327302 ?
Only clips short of the shifter handle shims I could think of -
VINCE Z28
« Reply #3 on: July 09, 2014, 02:01:14 AM »
They are called shifter shaft adapter clips, Pual Cangialosi, has a video showning them ( WWW.5speed.com ) But I don't do face book and don't have a way to get ahold of him. ie phone #. I don't know if he's the only one that has them? But it's not the same things at Summit. I'm not good at links sorry.
ss jim
« Reply #4 on: July 09, 2014, 02:54:49 AM »
Vince, try this  phone number. 561-743-5600.
VINCE Z28
« Reply #5 on: July 09, 2014, 02:57:53 PM »
Thanks Jim.
