Author Topic: Which is right?  (Read 6290 times)
coast car
Which is right?
« on: October 11, 2006, 07:01:26 AM »
I just got a 350 RS/SS convert. 60,000 miles
Production number 162282.
Engine number = VT228MS.
Tranny = P7S07
Axle = QL12222G
Alternator = 6M27
Distributor = 6M19
All December numbers(November tranny).
Norwood Plant
In reading things it says that all SS's are big blocks.
Confused, as other things I read say 350 is a small block.
Don't have casting numbers yet but here's cowl tag
There is a Holley carb on the motor(BB) but readouts here says it came a Qudra-Jet.
Looks like a riser plate between intake and carb? True part?
Clutched fan. True part? (no A/C)
Is an easy way to identify SB(looking in engine compartment, 1: hose exit from heater box? 2: rows on rad (2 or 3?))
Did these come with full size spare or space saver?
Update
12E                        E
67-12667 Nor 62757
765-Z          Y-2
D 2LG 3SL
4P
« Last Edit: October 11, 2006, 09:45:21 PM by coast car »
RAfbody
Re: Which is right?
« Reply #1 on: October 11, 2006, 12:51:57 PM »
I don't know what you are reading that says all SS's are big blocks but it is wrong.  It appears that the drivetrain you have listed is correct for a ss 350 car.  It would have had a quadrajet.  What are some casting numbers as well as the cowl tag numbers?  It would have come with a full size spare.
Russ
lakeholme
  • 68-12D L30/M35
Re: Which is right?
« Reply #2 on: October 11, 2006, 04:11:47 PM »
Go read it again.  It should say "All BB were SS".  There's a difference.  That does not rule out 350s.  All 67-68 350s were SS.
Go re-read this:  http://www.camaros.org/geninfo.shtml#PerformanceModels  --under performace engines.
And this:  http://www.camaros.org/engine.shtml#CamaroEngines  --under what was available.
Some of this stuff can be confusing....
