Author Topic: Trunk Lid Identification  (Read 75155 times)
Re: Trunk Lid Identification
« Reply #45 on: July 08, 2014, 10:20:29 PM »
LOS
« Reply #46 on: July 09, 2014, 03:38:43 PM »
Ok we still need more 03 & 04 69 cars (NOR & LOS) along with early 08-66 - 01-67  LOS
little_hoss
« Reply #47 on: July 09, 2014, 11:57:17 PM »
Just wondering if anyone has deciphered the trunk stamp codes  ???
Eric
1967 Base
1969 Base 307 3spd matching #'s X44
1968 C-10 Short Fleetside Custom
« Reply #48 on: July 10, 2014, 12:36:37 AM »
Thanks to ko-lek-tor for the heads up.
http://www.camaros.org/numbers.shtml#sheet
« Last Edit: July 10, 2014, 01:35:08 AM by cook_dw »
Jek9016
« Reply #49 on: January 27, 2015, 01:25:34 AM »
Thanks for the info
rsr
« Reply #50 on: January 27, 2015, 02:51:16 AM »
Did only the Los built 67 trunk lid get a plated latch plate as shown on the red lid?
« Reply #51 on: January 27, 2015, 06:20:31 PM »
My 67 05B
My 67 05B NOR (as well as the 04B LOS) has a plated latch.
« Reply #52 on: January 27, 2015, 07:10:20 PM »
I believe painted latches started with 68.  All 7s should be plated to the best of my memory.
« Reply #53 on: March 06, 2015, 03:44:03 PM »
I am adding another lid to this.  Found on Hemmings this morning.  12A (1966) LOS car.
« Reply #54 on: March 06, 2015, 11:31:00 PM »
Darrell, can you clarify exactly what details/areas of the trunk lid you need for your spreadsheet?
« Reply #55 on: March 07, 2015, 12:01:26 AM »
Tabs under the lip, holes in the outer panel for the T/A spoiler, build week, assembly plant and a photo. (69)
Tabs, center oval hole in outer panel, emblem cutouts on underside, build week, assembly plant and a photo.  (67)
« Reply #56 on: March 07, 2015, 03:34:05 AM »
OK. 04A Van Nuys build (NCRS shipper doc has production date of April 1, 1969), original paint under trunk lid. Sheetmetal date stamp T A 12. Photos tell the story. Interesting to note the original emblem holes in the lid where the spoiler sits, car is definitely a D80 and has one torsion rod thicker than the other.
Driver's side of trunk lid:
Passenger's side of trunk lid:
Lip detail (no tabs):
Emblem mounting and original (non-spoiler) emblem piercing:
Sheetmetal date code:
Front (leading edge) of spoiler mounting nut:
Rear (trailing edge) of spoiler mounting nut:
NOTE: spoiler is currently off the trunk lid during restoration, and was briefly removed in 1971 for the car to have it's drag-racing paint job applied, so no way to know if these nuts are original. However they do still have traces of dum-dum sealant around them.
Mike's (rszmjt's) picture shows captured washer on the nuts on his car.
« Reply #57 on: March 07, 2015, 03:53:58 AM »
Looks like someone made a mistake on the line...  The lower emblem holes do not show signs of nuts ever being on the paint..  First D80 car I have seen with the lower emblem holes punched..  Very cool..
« Reply #58 on: March 07, 2015, 05:33:57 AM »
Really? I guess I just assumed that all trunk lids were pierced at the time of manufacture ready for the standard (non-D80) emblem location, and additional holes were punched at the factory if the car had D80..... well that's something else I've learned!
« Reply #59 on: March 07, 2015, 07:44:09 AM »
Found the following thread which may explain the 2 sets of emblem holes:
http://www.camaros.org/forum/index.php?topic=3752.0
I haven't read right through it yet, but that is probably where I got the idea that (at least some) deck lids came pre-pierced in the std emblem location.
