Author Topic: Trunk Lid Identification  (Read 95529 times)
plumL78
Re: Trunk Lid Identification
« Reply #30 on: July 03, 2014, 06:34:19 PM »
The early 67 deck lids  also had the oval hole in the center like the nos ones do
« Reply #31 on: July 03, 2014, 06:37:14 PM »
Guys I have started a spreadsheet to help keep this info in order.  If you can give me your build date (on trim tag), Plant (NOR or LOS), stamping Plant Code (if readable if it isnt please note as such) & a pic that would be great.  Thanks, Darrell
« Reply #32 on: July 03, 2014, 06:39:04 PM »
Only ones I have seen have been the early LOS lids.  Do you know of or have any info of any lids with the oval center hole that came from NOR?
NoYenko
« Reply #33 on: July 03, 2014, 11:50:29 PM »
Darrell or George was the studs for the early 69 spoiler (Short one) and the later spoiler (longer one) in the same place on the lid?
I have both short & long spoilers and the stud location is the same. George
little_hoss
« Reply #34 on: July 04, 2014, 12:32:16 AM »
Going to try and post some pics of mine. 03E X44 71 71 car.
Eric
1967 Base
1969 Base 307 3spd matching #'s X44
1968 C-10 Short Fleetside Custom
« Reply #35 on: July 04, 2014, 01:36:13 AM »
Eric,
Do you have an overall pic of the lid?  Also can you make out the stamping in the center?
« Reply #36 on: July 04, 2014, 01:39:01 AM »
We need more cars guys!!! Keep them coming!
little_hoss
« Reply #37 on: July 04, 2014, 02:44:20 AM »
I'll get a better pic for you tomorrow.
Eric
1967 Base
little_hoss
« Reply #38 on: July 05, 2014, 09:44:17 PM »
Here are some more shots of my trunk lid from an 03E X44 car. It looks like my code is TA1 with an upside down 2 at the end. Hope these help  ;D
Eric
1967 Base
« Reply #39 on: July 06, 2014, 12:12:27 AM »
Thanks!
« Reply #40 on: July 06, 2014, 03:05:01 AM »
05D 68Z
Petes L48
« Reply #41 on: July 08, 2014, 02:56:09 AM »
Lid on a 67 11B LOS, stamped T43 (the 3 almost looks like a 5) and does not have the oval hole in the center toward the front edge.  One hole to the right of latch plate and two to the left were drilled out when a PO added the spoiler.  FWIW this is a convertible and the LH quarter is stamped H43 2 and the right is H43 3.
« Reply #42 on: July 08, 2014, 01:42:57 PM »
05D 68Z
Anyway you can make out the stamping?  Thanks for the pics!!
Thanks!!!
« Reply #43 on: July 08, 2014, 03:28:10 PM »
I've haven't looked in a while because the paint is so thick, but it looks like a D 8 something.
« Reply #44 on: July 08, 2014, 10:18:14 PM »
Also is your car NOR or LOS?
