Author Topic: Radiator Tank Codes 1969  (Read 3606 times)
Pacecar
« on: June 23, 2014, 10:27:46 PM »
Restoring a 1969 big block automatic with Turbo 400. I looked at the tank codes listed and did not see my code. The passenger side tank is stamped SB with a date code C. No codes on the driver side tank that I could see. It is a Harrison radiator. Any ideas what the SB code is ? has the correct brackets.  Thanks
VINCE Z28
Re: Radiator Tank Codes 1969
« Reply #1 on: June 30, 2014, 09:28:05 PM »
Pacecar,click on the red CRG in upper right hand conner, click on UNDERHOOD you'll see 1976-69 camaro cooling systems,that should tell you what you have or need.
« Reply #2 on: July 07, 2014, 08:26:45 AM »
SB - no idea.
