Author Topic: Real SS?  (Read 11778 times)
Re: Real SS?
« Reply #15 on: June 25, 2014, 04:53:23 AM »
easy to see the plate in your pic Zee, I don't see it in the first pic, unless it is buried under a lot of under coating...
geb78
Re: Real SS?
« Reply #16 on: June 25, 2014, 04:58:21 AM »
Thanks 69 Zee, I'm going to remove some of the undercoating to know for sure.  KurtS, I don't believe the transmission is original, it's too clean and no partial VIN stamp that I can find.
Stingr69
Re: Real SS?
« Reply #17 on: June 25, 2014, 04:29:04 PM »
There does not appear to be any frame rail reinforcement plate for the drivers side exhaust hangar in that picture.  The block stamp surface looks suspect but it is hard to see the detail.
69 Zee
Re: Real SS?
« Reply #18 on: June 26, 2014, 03:25:52 AM »
Yeah I see what your saying BULL, My pic shows the plate and a hanger fastened to it.   Geb looks like there may have been a hanger bracket there at one time, and we're seeing an image of were it once was as ko-lek-tor had pointed out.  X2 on scrape away to find the dual exh plate.
good luck
Darrell
