Author Topic: media blasting  (Read 5175 times)
Jason@JBR
media blasting
« on: June 09, 2014, 05:52:44 PM »
Needing some input on best type of media blasting to perform. Also, any suggestions on who can do it around Columbus, Ohio. Thank- you!
1969 L78 SS Camaro
1970 L78 SS Nova
1969 Chevelle
Kelley W King
Re: media blasting
« Reply #1 on: June 09, 2014, 07:03:20 PM »
I do not what is best but I have some hints. If anything such as dash,instruments,wiring, ect are left on the car the media will find it. Remove it all first or you will have to do it later and clean it. Plus after you blow it with compressed air, vacuum it 4 times. still wear goggles when you drive it for a while and be prepared to get it out of your ears ,nose and teeth. And by the way spraying with water 5 times will not help.
69 SS L78
67 SS Chevelle
64 Corvette
66 GTO Tiger Gold
77 Trans Am Special Edition
Jason@JBR
Re: media blasting
« Reply #2 on: June 09, 2014, 07:24:40 PM »
Sounds like a plan. Thank-you!
1969 L78 SS Camaro
1970 L78 SS Nova
1969 Chevelle
BillOhio
    • photobucket
Re: media blasting
« Reply #3 on: June 12, 2014, 01:28:56 AM »
Jason check your message box
1968 RS 327 4 speed
hotrod68
  • almost finished
Re: media blasting
« Reply #4 on: June 12, 2014, 01:39:08 AM »
  Soda blasting is good for items that are fragile or easily eroded. Hope this helps.
avnut
Re: media blasting
« Reply #5 on: June 13, 2014, 12:50:02 AM »
For smaller steel parts and some aluminuim ,glass bead media works well without removing base material.However it gets into every nook and cranny.Never add water as it really sticks then.Machine shops and some body shops may have glass bead cabinets.
Large parts can be sandblasted using fine grit sand,ground slag(black beauty).On thinner parts one has to be carefull that nozzle isnt too close or too great a air pressure used as it will peen and warp sheetmetal.
aka-Tom
68 RS/SS 396 04C Norwood Blue/Blue
427/M21/3.73 12 Bolt posi
Power drum,Std int,D55 console w/gauges,U73 rear antenna. PP code 12 bolt rear axle.
