Author Topic: Switching from a pwrglide to a TH350  (Read 8770 times)
dab67
  • 67 SS
« on: October 09, 2006, 01:27:45 PM »
Gentlemen:
Are there any major changes required if I wanted to change my pwrglide in my 67  to a TH350? How difficult would it be to keep the console intact with the shifter? Is there a kit that replaces the pwr glide numbering system to the 3 speeds in the TH350?
Just curious
dab67
hotrod68
  • almost finished
Re: Switching from a pwrglide to a TH350
« Reply #1 on: October 11, 2006, 03:21:53 AM »
You'll have to change the driveshaft yoke to the finer output spline of the 350 or an M-20 or M-21 yoke will work, but the driveshaft or crossmember won't have to be changed. Check the bolt pattern on the flexplate and be sure the 350 converter will bolt up, if not you'll need a 350 flexplate. Also, check the bolt hole alignment on your starter of you have to change flexplates--the straight pattern was for the smaller flexplate, the staggered pattern was for the larger 168-tooth flexplate. Pretty simple swap. I'd check with the repro companies about the console parts--the Turbo 400 stuff may be being reproduced now and will work. All in all, this is a fantastic swap to get rid of that "Slip-O-Matic". Low-end response is unbelievable compared to a Powerglide. Good luck.
dab67
  • 67 SS
« Reply #2 on: October 11, 2006, 09:56:05 AM »
Hotrod:
Thanks for the reply and info. Not sure what I am going to do, but now at least I have some idea on what I will need to replace and check before doing anything.
dab67
67camarorsss
« Reply #3 on: October 23, 2006, 09:16:08 PM »
Swap is a piece of cake. I've done it to several cars. The only major part you need to find is the shifter linkage.
- 1967 RS/SS 396/TH400 (loaded clone restification)
- 1998 Z28 LS1/M6 (daily driver)
- 2002 Z28 LS1/4L60E (12 sec toy/bookend to the 67)
