Author Topic: metal to metal glue?  (Read 4668 times)
vtfb68
« on: May 31, 2014, 05:59:18 PM »
What works best to re-bond the thin walnut grained console shift plate insert to the shift plate ?
     Thanks guys,
       Victor
68 08E LA RS Y2 749 L30 M35
WayneinNZ
Re: metal to metal glue?
« Reply #1 on: May 31, 2014, 08:44:07 PM »
You can use a contact adhesive such as ados F2.
You can get a smallish tube about half the size of a tube of toothpaste from a hobby store or a hardware store.
Apply to both surfaces and smear about with a flat stick to get a thin coat then wait till they "tack off", then put them together.
You probably wont need to completely cover the plate, the old glue residue should give you a clue as to how much is needed.
WARNING....... you will get one chance so make sure it is lined up correctly.
I hope that helps
Wayne
« Reply #2 on: June 02, 2014, 02:31:49 AM »
Weatherstrip adhesive will also work.
« Reply #3 on: June 02, 2014, 02:34:10 AM »
3M emblem adhesive always works extremely well....
JKZ27
« Reply #4 on: June 03, 2014, 10:47:24 PM »
Using reproduction parts, I tried weatherstrip adhesive and it did not hold for long. I ended up using a little JB weld.
John
68 RS Ash/Ivy Gold 327EFI M20
