Author Topic: 1969 Z/28 database questions  (Read 5110 times)
LeadFoot_69_Z/28
« on: October 06, 2006, 03:35:02 PM »
I have a 1969 Z/28.
Fisher Body Tag (Assembly date):  04C = April, 3rd week, 1969
Plant Code:  Norwood
VIN: 124379N632204 = indicates April, 1969
Engine Assemble date:  V0402DZ = April 02, 1969
Engine Block and cast date: 3932388 and C189 = March 18, 1969
Heads and cast date:  3927186 and C69, C79 = Marchl 06(and 07), 1969
Water pump:  3927170 dated K128 = November 12, 1969. Seems to early but is what is on the car?
Could the database administrator (Curt?) please provide data from other Norwood Z/28's produced in this same time frame?
Specifically:
(1)  What date 4053's do similar dated Z/28's have?
(2) What water pump (3927170 or 3953692) and cast date do similar dated Z/28's have?
(3) what date distributor do similar dated Z/28's have?
(4) what date alternator do similar dated Z/28's have?
Thank you very much for your time.  Once I finish writing down all the data from my Z/28, I will forward it to you.
Note:  The reason that I'm asking is because my car needs a 4053, distributor, alternator, maybe a water pump... And I want to make sure that I get reasonably dated parts.
Re: 1969 Z/28 database questions
« Reply #1 on: October 08, 2006, 03:00:04 AM »
Emailed.
GMS
  • Guest
« Reply #2 on: October 14, 2006, 01:12:09 AM »
Kurt
I have a 03E car and am also interested in the same info
124379N626190 / 12437NOR295590
6618 BLOCK CAST 3-18-9
Any help would be appreciated
