Author Topic: 67 camaro fuel gauge problem  (Read 9803 times)
x77-69z28
« on: May 19, 2014, 03:34:29 PM »
My 67 RS/SS with console gauges fuel gauge has stopped working. Any ideas? I think it is a ground problem as it is pinned fast full. Yet, I ran out of gas!
Buddy
Re: 67 camaro fuel gauge problem
« Reply #1 on: May 20, 2014, 01:57:58 AM »
check the ground ,only problem I ever had was once in a great while had to clean the ground by the tank. Use a little dielectric grease. Still retains the OE sending unit which works fine. Into a 46 yo S.W. gauge.
68ashgoldRS/SS
« Reply #2 on: May 20, 2014, 05:58:11 PM »
Yes, hopefully it's just the ground as janobyte describes... I went through this a few months back and discovered that I was not so lucky..  the Fuel sending unit in the tank had gone bad.  Here's my post troubleshooting this.  http://www.camaros.org/forum/index.php?topic=11830.msg96919#msg96919
Hope this helps, Ed
Ed Denney from South Jordan Utah
1968 Camaro RS/SS -Restored
1959 Chevrolet Corvette Restomod-Project in progress
1956 Dodge D100 Pickup -Project
1936 US Soldier, Dad -Best Friend
69pace
    • TeamCamaro - Moderator
« Reply #3 on: May 21, 2014, 02:51:38 AM »
Yes - check the sender ground first. You can troubleshoot the sender, harness and gauge following the troubleshooter over at TC: http://www.camaros.net/forums/showthread.php?t=195833
x77-69z28
« Reply #4 on: May 21, 2014, 03:49:10 PM »
Thanks guys, I will let you know how I make out.
