Author Topic: No fire to the plugs  (Read 11064 times)
kenmerr80
« on: May 16, 2014, 03:57:14 PM »
Ok here goes-my trade is construction-not mechanics-but know a little just to be dangerous so don't give me too much of a hard time.  Purchased a 69Z-has not been cranked in at least 12 years.  Changed plugs, wires, fluids.  Motor turns but not firing.  Pulled plug and watched as somebody turned motor and no spark on plug.  Changed coil.  No fire.  Next step I assume is inside distributor?  What direction do I take?   Thanks
Re: No fire to the plugs
« Reply #1 on: May 16, 2014, 04:41:11 PM »
What distributor?  Also did you check more than one plug to make sure it was or wasnt firing?
kenmerr80
« Reply #2 on: May 16, 2014, 05:17:51 PM »
Yes I had pulled 2 different plugs
« Reply #3 on: May 16, 2014, 05:22:11 PM »
What distributor?  HEI or points?  First thing I would do is pull the cap and make sure the rotor is turning while its cranking.
kenmerr80
« Reply #4 on: May 16, 2014, 05:25:16 PM »
Points.    Will pull the cap and check to see if turns.   thanks
« Reply #5 on: May 16, 2014, 06:16:10 PM »
Purchased a 69Z-has not been cranked in at least 12 years...  Motor turns but not firing.  Pulled plug and watched as somebody turned motor and no spark on plug.  Changed coil.  No fire.  Next step I assume is inside distributor?  What direction do I take?   Thanks
I can almost guarantee it is the points. Sitting that long the points get oxidized and corroded. With Key in off position, Remove distributor cap, 2 push down releases, take off rotor (2 screws) exposing points below. Take a small file (nail file will work) and put it between the contacts (apply a little pressure by pushing on the movable arm with your finger or screw driver) . Now, many manuals say NOT to file points, but they are not dealing with old, sitting idle stuff, so ignore that advice. After you file points, bump starter to close gap. Run (drag) a business card through the contacts a few times. This insures they are clean with no residue. Turn key on and crank engine watching for a spark jumping across points and looking for contact movement in and out. You may not see a visible spark easily, but with contact closed (key in on or run position)you can take a screw dr. and gently pry the contact arm and you should see a spark. Put everything back together and crank  checking for spark at plug. A cheap inline spark tester from harbor freight is good for this task. To check point gap is adequate, bump starter till points are in open position. Use a matchbook cover and set gap to cover thickness. A young fella may not have access to a dwell meter and this is a farmer's way and darn close.
kenmerr80
« Reply #6 on: May 16, 2014, 06:35:08 PM »
sounds good ko-lek-tor.   Will put your advice to use this evening and go from there.   thanks
« Reply #7 on: May 16, 2014, 06:51:58 PM »
Agreed.
Although I would go ahead and get a meter..  I cant tell you how many times I have used this little thing.
http://www.amazon.com/Actron-CP7605-Tachometer-Voltmeter-Analyzer/dp/B00062YUUS
« Reply #8 on: May 17, 2014, 02:59:42 AM »
Meter, definitely. Remove the old points, install the new ones, replace the cap, connect the dwell meter and remove the coil wire from the cap. Using the appropriate allen wrench or point tool to reach through the cap window, have an accomplice crank the engine: adjust the points to 30 degrees of dwell and you're done. Replace the coil wire and fire the engine. Sure is a lot easier on your back, and your eyes than trying to set point gaps with the distributor in place. Buy a cheap meter, or borrow from a willing neighbor if you can find one ! Also, make sure the wire from the distributor is connected to the negative coil terminal, not reversed.
If you think a single set of points are fun to set, try an old Mallory dual point YL-482 like I ran for years. You can do the same thing with them as you do a window type distributor cap, only you have to set both sets of points without the benefit of a window cap.
Regards - good luck and let us know how you do.
« Reply #9 on: May 17, 2014, 04:15:10 PM »
After filing/cleaning the points, use your test light; ground the clip and put the probe end on the coil (-) terminal while you crank the starter. The test light should flash on-off-on-off, confirming that the point circuit is good and the breaker plate ground wire isn't broken.
« Reply #10 on: May 20, 2014, 02:14:48 AM »
Maybe you know, but gap and dwell  are 2 different things. Must have a dwell meter to tune it correct. Seems 32 degrees was what we set the Z at, but it has been many years since I ran points. John Z wrote a great tech article on this site if you do a little searching. You are correct kol lector--width of a matchbook will set the correct air gap to get it home.
What did you find with it ??
hotrod68
  • almost finished
« Reply #11 on: May 20, 2014, 08:05:59 AM »
Width of a matchbook was for a Ford............blasphemy! Chuckle........
« Reply #12 on: May 26, 2014, 01:53:14 PM »
Matchbook cover stock is .012 +/- I supplied the rollstock to the 2 match manufacturers for years...
