Author Topic: Rear axle ID  (Read 5930 times)
avnut
Rear axle ID
« on: May 16, 2014, 01:07:09 AM »
Found the rear axle ID on my 68 .Perhaps someone here can tell me what it means.When I got car in 77 it had 4.88 posi in it.I changed the gears to 4.11 a couple years later.It was very likely changed from stock as the ring gear has a spacer between the carrier and ring.I think its a series 3 carrier?
The ID is  PP  0321G1 stamped into the forward side of right tube.On the corner of center section is cast K67.
aka-Tom
68 RS/SS 396 04C Norwood Blue/Blue
427/M21/3.73 12 Bolt posi
Power drum,Std int,D55 console w/gauges,U73 rear antenna. PP code 12 bolt rear axle.
Re: Rear axle ID
« Reply #1 on: May 16, 2014, 01:14:06 AM »
 This link has good information about the codes: http://www.camaros.org/drivetrain.shtml#AxleCodes
avnut
Re: Rear axle ID
« Reply #2 on: May 16, 2014, 01:24:38 AM »
Thanks for the link Mike.Looks like my axle originally had 3.07 12 bolt with one wheel peel.Made on Mar 21 by Detroit Gear -1 st shift if I understand the chart correctly.
aka-Tom
lakeholme
  • 68-12D L30/M35
Re: Rear axle ID
« Reply #3 on: May 16, 2014, 01:29:54 AM »
Scroll up a little from Mike's link to decode the casting date.
The CRG explanation is easier to read than Colvin's.
avnut
Re: Rear axle ID
« Reply #4 on: May 16, 2014, 01:40:21 AM »
Nov 6,67 was cast
You guys are making this too easy!
aka-Tom
lakeholme
  • 68-12D L30/M35
Re: Rear axle ID
« Reply #5 on: May 16, 2014, 01:55:11 AM »
It's really not that hard. It just takes practice and a great source like CRG!
"Give a man the decode... teach him how to decode..." you get the picture!
avnut
Re: Rear axle ID
« Reply #6 on: May 16, 2014, 02:13:31 AM »
Thanks yet again!
I now know how/when built,but I wont be going back there.I may regear to 3.73 and the posi stays.Perhaps the posi was dealer installed?
aka-Tom
Re: Rear axle ID
« Reply #7 on: May 16, 2014, 05:14:26 AM »
With that axle, I'd say it was originally an L35 with an auto.
Kurt
avnut
Re: Rear axle ID
« Reply #8 on: May 16, 2014, 09:45:39 AM »
I also suspect a lower HP 396 and Auto was original.Was doing some research of the console and floor area (thanks to this site)and thats why I am guessing an auto was in there.It has a rubber cable boot in the floor under the console.The speedo cable exits the firewall on the left side of steering coluum.The cutout for the 4 spd shifter is rough and jagged,so not factory and I have a SBC cross member for trans.
aka-Tom
