Author Topic: Source for correct rivets to install heat stove  (Read 5674 times)
Mikes69_Coupe
« on: May 09, 2014, 04:27:20 AM »
Howdy all. As I said in an earlier post, I'd like to remove the ex manifolds to de-rust them and install a new heat stove. Does anyone have a source for the correct rivets (and the 1 small bolt - or screw?) to attach it? How about a good method of removal for the original rivets and bolt - screw?? Was thinking of trying to use a chisel to pry them out, or just cut 'em, drill 'em, and replace. I want to go this route because this is an unrestored original ;D. Ideas?
Y'all take care,
Mike.
69 plain jane unrestored (but painted once) coupe, LeMans Blue, 86,264 miles, 327/210; PG; PS; A/C; Tinted glass. Original owner.
Re: Source for correct rivets to install heat stove
« Reply #1 on: May 09, 2014, 04:30:55 AM »
If they are like the rivets under the intake manifold, you should be able to 'chisel' them out and preserve them for re-use...
Mikes69_Coupe
« Reply #2 on: May 09, 2014, 04:54:34 AM »
thanks 69Z28-RS. Not much chance - they're pretty well gone due to the rust, just a small part of the head left - which is why the original stove fell of somewhere :-[. Thanks for the suggestion though.
Y'all take care,
Mike.
« Reply #3 on: May 09, 2014, 09:35:08 PM »
Bought mine from GM. I'll have to scrounge around to find them - the same type of spiral shank rivet was used on the oil splash shield under the intake. You can pry them out of old intakes if you can find a couple - usually pretty good condition (and I would do like restorers do, don't use them under the intake when you rebuild one - might work loose. Drill and tap for a good capscrew replacement). The original rivets have spiral shanks, not threads, and just tap into place.
Regards -
Mikes69_Coupe
« Reply #4 on: May 10, 2014, 03:12:14 AM »
Thanks z28z11.
Y'all take care,
Mike.
festival
« Reply #5 on: May 10, 2014, 05:56:32 PM »
On E-bay not mine but I used them for stoves on a manifold I restored...they worked OK.
http://www.ebay.com/itm/NOS-67-68-69-Chevy-Camaro-427-350-Exhaust-Manifold-Heat-Shield-Drive-rivets-/221401662454?vxp=mtr
Mikes69_Coupe
« Reply #6 on: May 10, 2014, 10:06:47 PM »
Thanks festival!
Mike.
